Brand
TP LINK 24-port 10/100 Switch
Quicklinx: 77SFWS00 Mfr#: TL-SF1024
Type: Fast Ethernet
Ports: 24
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£37.16 ex VAT
£44.59 inc VAT
TL-SF1024 24-port 10/100Mbps Ethernet Switch is designed for SOHO (Small Office/Home Office) or workgroup users. Rack-mount size metal case design combined with a safety certified internal power supply make the Switch the most robust product which is very cost-effective for less than 24 users environment. The plug-and-play and auto-negotiation capabilities allow the Switch to auto-detect its link partner (Ethernet adapter, for example) with the best speed. Each port provides full bandwidth (Maximum with 200Mbps in full duplex mode) without a traditional hub's collision phenomenon downgrading the performance. All ports can be the uplink (cascade) port, which is provided to link to another Switch for more ports expansion. Easy read LED indicators are supported for cable installation and normal operation diagnostics. The Switch can be used on desktop and rack-mount.
TP-Link TL-SF1024 - switch - 24 ports
Switch - 24 ports
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
24 x 10/100
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 24 ports
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
24 x 10/100
Status Indicators
Power, 100M device connected, link/activity
24 x 100Base-TX RJ-45
Internal power supply
Plug and Play, FCC
44 cm
18 cm
4.4 cm
10 - 90%
77SF C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £10.04
77SF C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £5.75
Type: Fast Ethernet
Ports: 24
Managed: No
POE: No
Brand: TP LINK
