The TL-WA5210G 2.4 GHz High Power Wireless Outdoor CPE is dedicated to WISP CPE solution and long distance wireless network solutions. It integrates the functions of a Wireless Access Point, WISP Client, high gain antenna and weatherproof enclosure. It features 12 dBi high gain antenna, high output power and high RX sensitivity can significantly extend the transmission range to deliver a more stable wireless connection. Complies with IEEE 802.11 b/g, TL-WA5210G creates an wireless network up to 54 Mbps, making it great for Internet surfing and files exchange.
Weatherproof design, durable outdoor solution
The TL-WA5210G is designed to work in harsh outdoor environment. Built with outdoor weatherproof enclosure and high durable of temperature hardware inside, the AP could work in some place with extreme bad weather conditions. Besides, the built-in 4000 V lightning and 15 KV ESD protection design would also help you to prevent storm/lightning surges and ensures reliable operation. -
High power and receive sensitivity
Just like a high-volume speaker to make your sound (wireless signal) travel further, the device features high power for higher speeds at further range for long distance applications giving your network the flexibility to go further. Signal degradation when traveling long distances is mitigated using high RX sensitivity meaning that you can get higher speed at further distances, just like a high-sensitivity headset, allowing the AP to detect and receive the weakest signals. These two aspects working together, ensure the signals can go further and bring higher speeds at the same distance than normal ones. -
Long distance outdoor, break the limitation of Wi-Fi
The TL-WA5210G features 12 dBi dual-polarized antennas which is the key feature to build long distance Wi-Fi connection. With software ACK timeout adjustable by setting the distance between two APs, it allows you to adjust the timeout value up to 15 km for outdoor long distance operation, or even 52 km with higher gain antenna support. -
Passive PoE supported for more flexible deployment
The TL-WA5210G is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP may be located even up to 200 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
- TP-Link TL-WA5210G - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Included Accessories
- PoE injector
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows Vista / XP / 7, Microsoft Windows 2000 / NT
- Power Over Ethernet (PoE) Supported
- PoE
- 26.5 cm x 12 cm x 8.3 cm
- 26.5 cm
- 12 cm
- 8.3 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 54 Mbps
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 15 km
- WISP mode, weatherproof
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g
Aerial
- Directivity
- Directional
- Gain Level
- 12 dBi
- PoE injector
- FCC, RoHS
- PoE
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
- -30 °C
- 70 °C
- 10 - 70%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
