Product
TP LINK 2.4GHz 9dBi Indoor Omni-directional Antenna
Quicklinx: CMB3WS00 Mfr#: TL-ANT2409CL
3 in stock
£5.19 ex VAT
£6.22 inc VAT
Standard delivery Delivered within 3-5 working days
Indoor omni-directional antenna TL-ANT2409CL operates in the 2.4-2.5 GHz band and provides 9dBi omni-directional operation, which largely extends the wireless range and delivers much better wireless performance. The antenna offers the RP-SMA female connector guaranteeing wider compatibility with most of the wireless equipments.
Replacing your Wi-Fi antenna with TL-ANT2409CL will significantly increase the range and strength of your Wi-Fi signal. This quality built omni-directional antenna is a direct replacement for the antenna that comes standard with your router, access point. Because it is omni-directional, no aiming is equired - it can send and receive Wi-Fi in all directions.
TP-Link TL-ANT2409CL - antenna
Antenna
Aerial Placing / Mounting
Indoor
Frequency Range
2.4 GHz
Gain
9 dBi
Directivity
Omni-directional
Antenna
Aerial
Indoor
Frequency Range
2.4 GHz
Gain
9 dBi
Directivity
Omni-directional
Horizontal Beamwidth
360°
Vertical Beamwidth
15°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA female
-10 °C
60 °C
10 - 90% (non-condensing)
Brand: TP LINK
Price Range Ex VAT: 0 - 50
