TP LINK 2.4GHz 24dBi Outdoor Grid Antenna N-Type Connector
Quicklinx: 8991WS00 Mfr#: TL-ANT2424B
This antenna operates in the 2.4-2.4835 GHz band and is designed for use outdoors.
TP-Link TL-ANT2424B - antenna
Antenna
100 cm 60 cm
3.5 kg
Intended For
Wi-Fi
Aerial Placing / Mounting
Outdoor, wall-mountable, pole mount
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.4835 GHz
Gain
24 dBi
Directivity
Directional
Antenna
100 cm
60 cm
3.5 kg
Aerial
Intended For
Wi-Fi
Compatibility
802.11 b/g
Frequency Range
2.4 - 2.4835 GHz
Gain
24 dBi
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
1.5:1
Horizontal Beamwidth
14°
Vertical Beamwidth
10°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x N-Series connector female
Mounting Kit
Included
Weatherproof
