TP LINK 16-Port Gigabit Switch
Quicklinx: 7YGSWS00 Mfr#: TL-SG1016D
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: No
28 in stock
£46.31 ex VAT
£55.57 inc VAT
The TL-SG1016D 16-port gigabit switch provides an easy way to make the transition to gigabit Ethernet. All 16 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SG1016D can save up to 40% of the power consumption, making it an eco-friendly solution for your business network.
  • Gigabit switch
    Featured with 16 10/100/1000 Mbps ports, TL-SG1016D greatly expands your network capacity, enabling instant large files transferring. So, power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly.
  • Go green with your Ethernet
    You now have the choice to go green when upgrading to a gigabit network! This TL-SG1016D 16-port gigabit switch features innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
  • Easy to use
    The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SG1016D 16-Port Gigabit Switch - switch - 16 ports - unmanaged
Switch - 16 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
29.4 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Status Indicators
Port transmission speed, power, link/activity
16 x 1000Base-T RJ-45
29.4 cm
18 cm
4.4 cm
10 - 90%
7YGS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
7YGS C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.13
7YGS C2G 2m Cat6a Shielded Patch - Blue In Stock £7.45
Ports: 16
Managed: No
POE: No
Brand: TP LINK
Price Range Ex VAT: 0 - 50
