TP Link 16 Port GigaBit Switch
Quicklinx: 77PQWS00 Mfr#: TL-SG1016
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: No
POE: No
46 in stock
£54.86 ex VAT
£65.83 inc VAT
The TL-SG1016 is specially designed for Ethernet (10Mbps), Fast Ethernet (100Mbps) and Gigabit Ethernet (1000Mbps). It is the perfect choice to improve the performance of Offices and Workgroups networks.
  • TP-LINK Green Technology
    This generation TL-SG1016 Gigabit Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. Besides, 80% of the packaging material can be recycled.
  • High performance
    All 16 ports are Gigabit RJ-45 ports which can provide large file transferring and also be compatible with 10Mbps and 100Mbps Ethernet devices. Featuring non-blocking switching architecture, TL-SG1016 forwards and filters packets at full wire-speed for maximum throughput. With 10KB Jumbo frame, the performance of large files transfers is improved significantly. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the tra­ffic congestion and make The TL-SG1016 work reliably. It's a perfect choice to update your network to Gigabit while protecting your previous investment properly.
  • Easy to use
    The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SG1016 - switch - 16 ports - rack-mountable
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
16 x 1000Base-T RJ-45
44 cm
18 cm
4.4 cm
10 - 90%
77PQ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
77PQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
77PQ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.36
77PQ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.62
Ports: 16
Managed: No
POE: No
Brand: TP LINK
Price Range Ex VAT: 50 - 100
