TP LINK 16 port Gigabit Smart Switch  with 2 SFP slots
Quicklinx: 88Y6WS00 Mfr#: TL-SG2216
TP-LINK gigabit smart switch TL-SG2216 is equipped with 16 gigabit RJ45 ports and 2 combo SFP slots. The switch provides high performance, enterprise-level QoS, useful security strategies and rich layer 2 management features.
TP-LINK gigabit smart switch TL-SG2216 is a cost-eff­ective product solution for the small and medium business. TL-SG2216 has useful security features. The storm control feature protects against broadcast, multicast and unknown unicast storm. Quality of Service (QoS, L2 to L4) provides enhanced traffic management capabilities to move your data smoother and faster. Anymore, the easy-to-use web management interfaces, along with CLI, SNMP and RMON, mean faster setup and configuration with less downtime. For workgroup and departments requiring cost-sensitive layer 2 switch and gigabit capability, TP-LINK gigabit smart switch TL-SG2216 provides you the ideal access-edge solution.
  • Advanced QoS features
    To integrate voice, data and video service on one network, the switch applies rich QoS policies. Administrator can designate the priority of the traffic based on a variety of means including port priority, 802.1p priority and DSCP priority, to ensure that voice and video are always clear, smooth and jitter free.
  • Abundant layer 2 features
    For more application of layer 2 switches, TL-SG2216 supports a complete lineup of layer 2 features, including 802.1Q tag VLAN, port isolation, port mirroring, STP/RSTP/MSTP, link aggregation group and 802.3x flow control function. Any more, the switch provides advanced features for network maintenance such as loop back detection, cable diagnostics and IGMP snooping. IGMP snooping ensures the switch intelligently forward the multicast stream only to the appropriate subscribers while IGMP throttling and filtering restrict each subscriber on a port level to prevent unauthorized multicast access.
  • Enterprise level management features
    TL-SG2216 is easy to use and manage. It supports various user-friendly standard management features, such as intuitive web-based Graphical User Interface (GUI) and industry-standard Command Line Interface (CLI). SNMP (v1/2/3) and RMON support enables the switch to be polled for valuable status information and send traps on abnormal events.
TP-Link JetStream TL-SG2216 - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 2 x combo Gigabit SFP
Performance
Bandwidth: 32 Gbps
MAC Address Table Size
8K entries
Jumbo Frame Support
10160 bytes
Remote Management Protocol
HTTP
Auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
44 cm x 26 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Gigabit Ethernet
Ports
Performance
Bandwidth: 32 Gbps
8K entries
Jumbo Frame Support
10160 bytes
HTTP
Status Indicators
Power, system, 1000M device connected, link/activity
16 x 1000Base-T RJ-45 , 2 x Ethernet 1000 - SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Included
FCC
44 cm
26 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
88Y6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
Resources
The following resources are available for the TP LINK 16 port Gigabit Smart Switch with 2 SFP slots
