Brand
TP LINK 16-Port Gigabit Desktop/Rackmount Switch with 8-
Quicklinx: DD0WWS00 Mfr#: TL-SG1016PE
The TL-SG1016PE is an 16-Port Gigabit Desktop/Rack mountable Switch with 8 ports supporting the PoE+ standard. It provides a simple way to expand a wired network by transferring power and data over a single Ethernet Cable. With a total power budget of 124W, up to 30W per port, TL-SG1016PE can power more high-powered devices such as wireless Access Points (APs), IP Cameras or IP Phones. Moreover, with innovative energy-efficient technology, the TL-SG1016PE can save up to 75% of the power consumption, making it an eco-friendly solution for your business network.
TP-Link TL-SG1016PE - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 8 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
110 W
Performance
Forwarding performance: 23.8 Mpps , Switching capacity: 32 Gbps
Virtual interfaces (VLANs): 128 , IGMP snooping groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, Quality of Service (QoS), Cable Diagnostics Function, loop prevention, metal housing, DiffServ Code Point (DSCP) support, Storm Control, PoE management, Link Aggregation
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p, IEEE 802.3at
29.4 cm x 18 cm x 4.4 cm
5-year warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
110 W
Performance
8K entries
Jumbo Frame Support
9KB
8 x 1000Base-T RJ-45 PoE+ , 8 x 1000Base-T RJ-45
FCC
29.4 cm
18 cm
4.4 cm
Limited warranty - 5 years
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
