Product
TP LINK 16 Port 10/100Mbps + 2 Port Gigabit Smart Switch
Quicklinx: 8R2XWS00 Mfr#: TL-SL2218
The TL-SL2218WEB Gigabit-Uplink Web Smart Switch fully complies with IEEE 802.3/802.3u/802.3ab/802.3z Ethernet standards. It provides 16 10/100Mbps and 1 10/100/1000Mbps UTP/STP RJ45 ports with auto-MDI/MDIX and 1 SFP independence expansion slots supporting MiniGBIC modules. It also provides Web-based management functions including the system, port network, VLAN, Trunk, Priority and security etc. Its standard 19-inch rack-mountable steel case and intelligent management makes it is suitable for small, middle and large networks.
TP-Link Web Smart Switch TL-SL2218WEB - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100 + 1 x SFP + 1 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
HTTP
Auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, store and forward, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
44 cm x 18 cm x 4.4 cm
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8K entries
HTTP
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
16 x 100Base-TX RJ-45 , 1 x 1000Base-T RJ-45 , 1 x SFP (mini-GBIC)
Internal power supply
FCC
44 cm
18 cm
4.4 cm
10 - 90%
8R2X C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
8R2X C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
8R2X C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
8R2X C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.36
