TP LINK 16-Port 10/100M Switch
Installation required? Contact us today!
Quicklinx: 896HWS00 Mfr#: TL-SF1016DS
Type: Fast Ethernet
Ports: 16
Data Transfer Rate: 100Mbps
Managed: No
POE: No
24 in stock
£30.48 ex VAT
£36.57 inc VAT
The TL-SF1016DS Fast Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 100Mbps network. All 16 ports support auto MDI/MDIX, no need to worry about the cable type, simply plug and play. Moreover, with the innovative energy-efficient technology, the TL-SF1016DS can save up to 25%* of the power consumption and 70% of the packaging material can be recycled, making it an eco-friendly solution for your business network.
High Performance
The rack-mount size metal case design combined with a safety certified internal power supply make the Switch the most robust product which is very cost-effective for a less than 16 user environment. Featuring non-blocking switching architecture, TL-SF1016DS forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1016DS work reliably.
TP-LINK Green Technology
This new generation The TL-SF1016DS Fast Ethernet Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. Besides, 70% of the packaging material can be recycled.
Easy to Use
The auto features of this fast ethernet switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10 or 100 Mbps) and intelligently adjusts for compatibility and optimal performance.
  • High performance
    The rack-mount size metal case design combined with a safety certified internal power supply make the switch the most robust product which is very cost-effective for a less than 16 user environment. Featuring non-blocking switching architecture, TL-SF1016DS forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1016DS work reliably.
  • TP-Link green technology
    The TL-SF1016DS Fast Ethernet switch features energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. Besides, 80% of the packaging material can be recycled.
  • Easy to use
    The auto features of this Fast Ethernet switch make installation Plug and Play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables.
TP-Link TL-SF1016DS - switch - 16 ports - rack-mountable
Switch - 16 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), packet filtering, store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
29.4 cm x 18 cm x 4.4 cm
Switch - 16 ports
Enclosure Type
Desktop, rack-mountable
Subtype
Fast Ethernet
Ports
16 x 10/100
8K entries
Status Indicators
Power, link/activity
16 x 100Base-TX RJ-45
Plug and Play, FCC, RoHS
29.4 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
896H C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
896H C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
896H C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.98
896H C2G 2m Cat6a Shielded Patch - Blue In Stock £7.38
Type: Fast Ethernet
Ports: 16
Managed: No
POE: No
Brand: TP LINK
Price Range Ex VAT: 0 - 50
