TP LINK 150Mbps Wireless Lite N Access
Quicklinx: 77RQWS00 Mfr#: TL-WA701ND
  • IEEE 802.11n
2 on order, delivery delayed
The TP-LINK Wireless N Access Point TL-WA701ND is designed to establish or expand a scalable high-speed wireless N network or to connect multiple Ethernet enabled devices such as game consoles, digital media adapters, printers, or network attached storage devices to a wireless network. It is designed using Align™ 1-stream technology to provide high-speed, unrivaled wireless performance for your network at 150Mbps. The APs support a host of different functions that makes your wireless networking experience more flexible than ever before. Now, you can enjoy a better Internet experience when downloading, gaming, video streaming or with any other application that you may wish to use.
Wireless N - Speed & Range
Complying with the IEEE 802.11n standard, TL-WA701ND can easily establish a wireless network and get up to 9X the speed and 4X the range of conventional 11g products. With Align™ technology based on the IEEE 802.11n 1-stream specification shows improved performance over the existing 802.11g technology, TL-WA701ND delivers performance enhancements, allowing you to have a more joyful surfing experience, including sharing files, watching streaming media.
Multiple Operating Modes - Easy to Build WLAN
Supports multiple operating modes (Access Point, Multi-SSID, Client, Universal/ WDS Repeater, Bridge with AP) to enable various wireless applications to give users a more dynamic and comprehensive experience when using their AP. Multiple operating mode also helps you easily to build wireless network for hard-to-wire locations or eliminating wireless dead zone.
WPA / WPA2 Encryptions - Advanced Security
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside threats. TL-WA701ND provides WPA/WPA2 encryptions (Both Personal and Enterprises) that are created by the WI-FI Alliance industry group, promoting interpretabilities and security for WLAN.
WPS Button - One Button Setup Security (WPS Compatible)
The TL-WA701ND features WI-FI Protected Setup™ (WPS) that allows users to almost instantly setup their security simply by pressing the "WPS" button automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Passive PoE Supported - More Flexible Deployment
The TL-WA701ND is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP may be located even up to 100 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
Easy to Use
Even novice users can easily setup their networking products. The device adds quick setup on the software that leads you through the setup process step-by-step, and even save the configuration text in your computer.
Note: Above information apply to TL-WA701ND version 2.0 ONLY.
  • Wireless N - speed and range
    Complying with the IEEE 802.11n standard, TL-WA701ND can easily establish a wireless network and get up to 9x the speed and 4x the range of conventional 11g products. With Align technology based on the IEEE 802.11n 1-stream specification shows improved performance over the existing 802.11g technology, TL-WA701ND delivers performance enhancements, allowing you to have a more joyful surfing experience, including sharing files, watching streaming media.
  • CCA technology - stable wireless signals
    Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance. Using channel detection, CCA ensures that only free channels may be bound with, in order to maintain a neighborly atmosphere. Also, this channel detection can also detect in real time whether a channel becomes free at which point you can change to that channel in order to multiply your data transmission rates.
  • Multiple operating modes - easy to build WLAN
    Supports AP client, bridge, repeater and AP operation modes to enable various wireless applications to give users a more dynamic and comprehensive experience when using their AP. Multiple operating mode also helps you easily to build wireless network for hard-to-wire locations or eliminating wireless dead zone.
  • WPA/WPA2 encryptions - advanced security
    As for the security of Wi-Fi connection, WEP encryption has been no longer the strongest and safest guards for outside threats. TL-WR701ND provides WPA/WPA2 encryptions that are created by the Wi-Fi alliance industry group, promoting interpretabilities and security for WLAN.
  • QSS button - one button setup security
    Compatible with Wi-Fi Protected Setup (WPS), TL-WA701ND features quick security setup that allows users to almost instantly setup their security simply by pressing the "QSS" button automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
  • Passive PoE supported - more flexible deployment
    The TL-WA701ND is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP can be located even up to 100 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
TP-Link TL-WA701ND Lite N 150Mbps Access Point - radio access point - Wi-Fi
Radio access point
External
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
15 cm x 10 cm x 2.8 cm
Radio access point
15 cm
10 cm
2.8 cm
External
Wireless
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM
Frequency Band
2.4 GHz
Status Indicators
Power, system, link/activity
Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode
Encryption Algorithm
WPA, WPA2
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
4 dBi
1 x 100Base-TX - RJ-45
PoE
External power adapter
10 - 90%
