The MC210CS is a media converter designed to convert 1000BASE-LX/LH fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-LX/LH standards, the MC210CS is designed for use with single-mode fiber cable utilizing the SC-Type connector. The MC210CS supports longwave (LX) laser specification at a full wire speed forwarding rate. It works at 1310nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19''system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC210CS will transmit at extended fiber optic distances utilizing single-mode fiber up to 15 kilometers.
- TP-Link MC210CS - fibre media converter - GigE
- Fibre media converter - RJ-45 / SC single-mode
- Form Factor
- External
- Cabling Type
- 1000Base-FX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 15 km
- 9.5 cm x 7.3 cm x 2.7 cm
- Designed For
- P/N: TL-MC1400, TL-SG3452XP V1
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- GigE
- 1 Gbps
- 1310 nm
- 15 km
- Status Indicators
- Power, receive, link/activity
- Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode
- IEEE 802.3z, IEEE 802.3ab, IEEE 802.3x
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-FX - SC single-mode female x 2
- Power Device
- External power adapter
- 9.5 cm
- 7.3 cm
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
