Toshiba X300 6TB 3.5" 7200RPM 128MB SATA6GB/s Extreme HDD
Quicklinx: BKTGWS00 Mfr#: HDWE160EZSTA
Extreme Performance. Powered by Innovation
Ideal for Graphic Design / Gaming / Animation
6TB
7200rpm
128MB Buffer
High Storage Density and Capacity
High-precision head positioning supported by advanced format technology (physical 4 KB sector) and dual stage actuators, for impressive high storage density and capacity.
Enhanced Real-Time Performance
Self-contained original cache algorithm and buffer management onboard. Optimization of cache allocation during reading and writing for improved performance in real-time domains
High Performance with Curbed System-Induced Vibration
Adoption of a tied spindle motor stabilizes the motor drive shaft at both ends to curb system-induced vibration. The interior plotter is also stabilized, raising performance on the strength of the enhanced designated sector-tracking system during reading and writing operations.
Data Protection Technology
Ramp loading technology reduces head wear and tear improving drive reliability.
  • Powerful performance
    Performing at 7200 RPM, and with a 128 MB buffer, your data is stored securely and accessed quickly. Whether it's a quick game save, a large file that needs backing up, or working with multiple applications, the X300 retains its high-performance all day, every day. Ideal for graphic designers and creative professionals, the X300 is capable of handling almost any workload.
  • Responds in an instant
    The X300's dual-stage actuator design improves positional accuracy, negating the effects on head-track alignment that vibrations can cause. This design makes for more precise, faster read and write speeds for instant access to your data.
  • Premium storage
    For when you need more, the X300 delivers. The X300 is able to meet your every requirement, with fast read and write speeds and secure design, making it ideal for demanding roles such as professional computing and PC gaming.
  • Advanced read and write technology
    Between the Perpendicular Magnetic Recording technology - which can deliver more than three times the storage density of traditional recording, and accounts for the X300's high capacity - and the Tunnel Magneto-Resistive recording technology - for improved stability - the X300 is equipped for fast and secure reading and writing of data.
  • Keep data secure
    The X300's design includes an internal shock sensor, ensuring no data is lost. In addition, ramp loading technology means that when the hard drive or desktop PC are being transported, the drive slider does not make contact with the disk and risk wearing or data loss.
Toshiba X300 - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Spindle Speed
7200 rpm
Shock sensor, Native Command Queuing (NCQ), Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA), Tied Spindle Motor
101.6 mm x 147 mm x 26.1 mm
770 g
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
770 g
Performance
Average Latency
4.17 ms
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
RoHS
