This is a wireless mouse with LED tracking light technology for excellent tracking accuracy on almost all surfaces. It features the USB nano receiver that can be stored inside the mouse body.
- Toshiba MR100 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- 5.8 cm x 9.51 cm x 3.55 cm
- 56 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1600 dpi
- Scrolling wheel, Blue LED technology
- Battery
- AAA type
- OS Required
- Microsoft Windows 7, Windows 8.1, Windows 10
- Designed For
- Dynabook Toshiba Portégé A30, X20W, X30, Z20T, Z30, Z30t, Z40; Toshiba Satellite Pro A30, A40, A50, C70, R40, R50; Toshiba Tecra A40, A50, X40, Z40, Z40t, Z50; Satellite Z30
- Mouse
- Wireless Receiver
- 5.8 cm
- 9.51 cm
- 3.55 cm
- 56 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1600 dpi
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- 2 AAA batteries
- SASO
- AAA type
- OS Required
- Designed For
- Dynabook Toshiba Portégé A30-C-13N, A30-C-180, A30-C-1D0, A30-C-1HE, A30-C-1HF, A30-C-1RH, A30-D-10E, X20W-D-11M, X20W-D-123, X20W-D-12J, X30-D, X30-D-10G, X30-D-10J, X30-D-10K, X30-D-10L, X30-D-10V, X30-D-10W, X30-D-10X, X30-D-10Z, X30-D-110, X30-D-11C, X30-D-12M, X30-D-12Q, X30-D-12Z, X30-D-15D, X30-D-15F, X30-D-15N, X30-D-15P, X30-D-17G, X30-D-18F, X30-D-19X, Z20T-C-13R, Z20T-C-13T, Z20t-C-13X, Z20t-C-13Z, Z20t-C-155, Z30-B-12J, Z30-C-13G, Z30-C-16H, Z30-C-16J, Z30-C-16L, Z30-C-16N, Z30-C-16Z, Z30-C-188, Z30-C-193, Z30-C-1CV, Z30-C-1CW, Z30t-C-139, Z40-C-103 , Dynabook Toshiba Satellite Pro A30-C-130, A30-C-14E, A30-C-182, A30-C-1D0, A30-C-1DU, A30-C-1EP, A30-D-10E, A40-C-14T, A40-C-150, A40-C-1D7, A40-C-1EE, A40-D-117, A50-C-12P, A50-C-12W, A50-C-1GP, A50-C-1GR, A50-C-1HG, A50-C-1L2, A50-C-1LR, A50-C-1ML, A50-C-1MM, A50-C-1NC, A50-C-1ND, A50-C-202, A50-C-207, A50-C-209, A50-C-21T, A50-C-21U, A50-C-23P, A50-C-24W, A50-C-270, A50-D-10J, A50-D-110, A50-D-12P, A50-D-12U, A50-D-12X, A50-D-131, A50-D-13Q, A50-D-14M, A50-D-14N, A50-D-14P, A50-D-14U, A50-D-14X, A50-D-14Z, A50-D-18V, A50-D-18W, A50-E-11D, A50-E-11E, C70-C-1FM, C70-C-1FQ, C70-C-1FR, R40-C-10W, R40-C-112, R40-C-114, R40-C-11J, R40-C-128, R40-C-12H, R40-C-12W, R40-C-13K, R50-C-104, R50-C-135, R50-C-136, R50-C-14H, R50-C-14J, R50-C-14K, R50-C-14N, R50-C-150, R50-C-151, R50-C-15W, R50-C-167, R50-C-179, R50-C-17C, R50-D-104 , Dynabook Toshiba Tecra A40-C-147, A40-C-1DE, A40-C-1DF, A40-C-1DG, A40-C-1E5, A40-C-1HT, A40-C-1KF, A40-C-1WK, A40-D-12P, A50-C-1F8, A50-C-1G1, A50-C-1ZT, A50-C-1ZZ, A50-C-200, A50-C-218, A50-C-256, A50-D-10M, A50-D-12D, A50-D-12Q, A50-D-13U, A50-E-11F, X40-D-10G, X40-D-10H, X40-D-10Z, X40-D-152, X40-D-15F, Z40-C-11E, Z40-C-11N, Z40-C-11X, Z40-C-12X, Z40-C-136, Z40t-C-10L, Z40t-C-10M, Z50-C-10P, Z50-C-115, Z50-C-11C, Z50-C-11E, Z50-C-11F, Z50-C-11V, Z50-C-138, Z50-C-13C, Z50-C-140, Z50-C-151, Z50-D-10V, Z50-D-11L, Z50-E-106, Z50-E-107
