This is a promotional product to be bundled with Microsoft Office Home & Business 2016 only - if you would like to buy this product separately please type BR0Y in the search bar at the top of this webpage
The USB 2.0 standard A Type has a size of 12 mm width and a height of 4.5 mm. Suitable in all USB 2.0 ports which is standard in every PC. Data transmission is possible in both directions.
Devices can be connected and detected during operation. Just plug and play and transfer your favorite music and images.
Low power consumption is achieved thanks to Toshiba's original technology, such as multi-layering of high-speed NAND flash memory and a dedicated low-power-consumption ASIC controller. As a result, power consumption of notebook PCs is minimized even when using a USB flash memory.
USB 2.0 standard
The USB 2.0 standard A Type has a size of 12 mm width and a height of 4.5 mm. Suitable in all USB 2.0 ports which is standard in every PC. Data transmission is possible in both directions. -
Hot plug and unplug
Devices can be connected and detected during operation. Just plug and play and transfer your favorite music and images. -
One of the lowest power consumption in the industry
- Toshiba TransMemory U202 - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 2.0
- Storage Capacity
- 64 GB
- Enclosure Colour
- White
- OS Required
- Apple MacOS X 10.0.2 or later, Microsoft Windows 2000/XP/Vista/7/8
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Enclosure Colour
- White
- Read Rate
- Up to 18 MB/s
- Write Rate
- Up to 5 MB/s
- Interface Type
- USB 2.0
- OS Required
- Limited warranty - 5 years
- 21.4 mm
- 51.4 mm
- 8.4 mm
- 8 g
- 0 °C
- 50 °C
- 20 - 95% (non-condensing)
