Toshiba Tecra Z50-C-10M i5-6200U 8GB 256SSD 15.6" Win 7 Pro
Quicklinx: BVZKWS00 Mfr#: PT571E-01E002EN
  • Core i5
  • Microsoft Windows 7 Professional
  • IEEE 802.11n
With the super thin and light Tecra Z50 laptop, you can see more on the 15.6" non-reflective screen, do more with powerful processors - and achieve more using full-size ports. With a clean design and long-lasting battery, the Z50 can easily be used for all-day productivity. Whether you're sharing a presentation or populating a spreadsheet, the Tecra Z50 is ultra-responsive and performs at speed.
  • Designed for business
    The Tecra Z50 is ready to meet your business demands. Starting at a light 1.7kg and highly robust, it's the perfect companion as you move between desks and meeting spaces. Even without an extended battery, you get a long-lasting 10 hours on a single charge. And if you're working in a patch of sunlight, you won't see any glare on the large 39.6 cm (15.6") non-reflective HD screen. So it's really convenient to type emails or create documents at any time - even in dimly-lit conditions, using the illuminated keyboard.
  • Made for multi-tasking
    With powerful processors, the Z50 has all the power and drive you need to move between multiple tasks. Tecra Z50 offers plenty of storage, faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
  • Fully connected
    The Tecra Z50 is packed with full-size ports, so you won't need any special adapters to work more flexibly. You can transfer data to other devices much faster, using three of USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Plus, it's easy to connect to monitors and displays with RGB. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. Connecting to your peripherals is fast and simple with the optional docking solution, which aligns with the other models in Toshiba's latest business line-up. The SD card slot boosts storage too.
  • You can depend on it
    The ultra-durable Tecra Z50 was designed to withstand the pressures of professional life and meet Toshiba's quality standards. With its light yet strong magnesium chassis, the Z50 is highly durable too, so you can be sure of a better return on your investment.
  • Secure and easy to manage
    The Z50 is built for business, and comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z50 needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The standard fingerprint reader makes it easy and secure to log on to your PC too, while the 3D sensor knows to take care of your data if your laptop falls.
  • Business improvements all round
    Toshiba is constantly improving its models to help meet more of your business needs. So silent cooling and better speakers were added to the design to make the Z50 more durable and user-friendly. With a larger HD screen and improved backlit keyboard, plus larger Accupoint and touchpad, it's easier to view your laptop and navigate your way around it too.
  • Synergy across devices
    The Tecra Z50 shares many features with the latest business line-up from Toshiba, to ensure consistency across your company - no matter which models you choose. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z50 also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility. All Toshiba laptops share the same software image, for easy customization in one go. Plus, the fingerprint reader, non-CSV display, webcam, magnesium chassis, Accupoint and docking connector all come as standard too.
Dynabook Toshiba Tecra Z50-C-10M - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
DualPoint
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Tile black (keyboard), steel grey with precious hairline
37.9 cm x 25.8 cm x 2.325 cm
2 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Numeric Keypad
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
VGA , LAN , Headphone/microphone combo jack , 4 x USB 3.0 , HDMI , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Dockable
Security
Administrator password, system password, hard drive password, USB Sleep-and-charge ports, 3D accelerometer
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
