One of Toshiba's thinnest, lightest business laptops yet, the premium 35.6 cm (14") Tecra Z40-A match's ultra-portability with a long-lasting battery and larger screen that lets you do more on the go. Beneath the clean design that's standard across this line-up, the Z40-A is powered by Intel Core processor, for all the speed and responsiveness you need. Its full-size ports are made for more flexible working too, while high-level security and manageability technologies and an ultra-durable chassis will protect your business data everywhere. For large-screen productivity that travels further, there's the Tecra Z40-A.
Made for mobile business
The Tecra Z40-A is ready to do business everywhere. Starting at an ultra-light and highly robust, it's the perfect companion to take on your travels. Even without an extended battery, you get a long-lasting use on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 35.6 cm (14") non-reflective HD screen. So it's really convenient to type emails or create documents when you're working out of the office - even in dimly-lit conditions, using the illuminated keyboard. -
Multi-tasking on the move
With Intel Core processor, the Z40-A has all the power you need to multi-task on the move. And with high-performance SSDs, the Tecra Z40-A offers plenty of storage, faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease. -
Fully connected
The Tecra Z40-A is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using three of the USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. Connecting to your peripherals is fast and easy with the docking solution, which aligns with the other models in Toshiba's latest business line-up. The SD card slot boosts storage too. -
Secure and easy to manage
The Z40-A is built for business, and comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z40-A needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The fingerprint reader makes it easy and secure to log on to your PC too, while the 3D sensor knows to take care of your data if your laptop falls. -
Business improvements all round
Toshiba is constantly improving its models to help meet more of your business needs. So Toshiba added silent cooling and better speakers to the Z40-A to enhance the performance and make it more user-friendly. With a HD screen and improved backlit keyboard, plus larger Accupoint and touchpad, it's easier to view and navigate your laptop too.
- Dynabook Toshiba Tecra Z40-A-16Z - 14" - Intel Core i5 - 4310U - vPro - 4 GB RAM - 128 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4310U / 2 GHz, up to 3 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Input Device
- DualPoint
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 9 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Graphite black with grooved texture, matte black keyboard
- 33.8 cm x 23.6 cm x 2.04 cm
- 1.47 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- International warranty - 1 year - carry-in
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4310U / 2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD mSATA SATA 3Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Max Allocated RAM Size
- 1696 MB
- Camera
- Resolution
- 2 Megapixel
- Video Resolutions
- 1980 x 1080
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, DualPoint
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V, 3.42 A
Connections & Expansion
- VGA , LAN , Headphone/microphone combo jack , HDMI , 3 x USB 3.0 , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 1.47 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
