The 39.6 cm (15.6") Tecra W50-A is the ultimate mobile powerhouse. Built to take on the most intensive computing demands, this professional workstation delivers a mighty performance - wherever your business takes you. Driven by powerful Intel quad core processor and fast NVIDIA Quadro graphics, the W50-A handles multiple, graphics-intensive applications and demanding system tasks with absolute ease. From its super responsive SDD drives to the reliable design, extreme performance has never been so portable.
Extreme performance on demand
The Tecra W50-A isn't called a workstation for nothing. Driven by Intel quad core processor, it's a powerhouse of speed and strength that will cut through the heaviest of workloads. So you can rely on an extreme performance, right when you need it. Nothing will get in the way of your workflow as you switch between multiple applications or documents. Even if those applications are graphics-rich and particularly demanding, the dedicated NVIDIA Quadro graphics card with fast GDDR3 memory delivers a dramatically higher performance to accelerate tasks like video editing and creating animations. -
Smarter drives, faster response
Some commands should just happen, fast. Boot up, shut down and application start-up. Opening, saving or storing files. None of these should get in the way of a busy professional under pressure to deliver. And with Solid State Drive, the Tecra W50-A really delivers - through a much higher responsiveness that helps your work flow quickly and smoothly. So, just like your workstation, you can zip through essential processes, whizz through system tasks and perform brilliantly. -
Mighty mobility
The Tecra W50-A is as mobile as it is mighty, with all the ports and interfaces you need to work flexibly. There's the high-quality Wi-Fi with Bluetooth, so you can always access the important business information you need. And the USB 3.0 ports to transfer your data to other devices at blazing speeds. If you want to share or present your work, it's easy to connect to high-resolution professional displays, using DisplayPort. Or do it wirelessly, using the Intel Wireless Display (WiDi). You can even get faster access to your local network, with Gigabit LAN. -
Better connected
With the extra connectivity you get from the docking port, you can make the most of all your peripherals from the comfort of your desk. So it's easy to create a more comfortable and productive working environment. You might want to connect to a high-speed drive to quickly back up your day's work. Or use your printer to create hard copies of your meeting notes. And you can simply add a display if you prefer dual screens when working on multiple projects or documents. -
Advanced security
The Tecra W50-A is full of advanced security features to help keep your business-critical data safe. Along with the Trusted Platform Module (TPM), it protects the data on your local storage. From the start, a secure fingerprint reader makes signing on quick and personal to you, while Intel Anti-Theft means your laptop can be locked-down remotely to prevent unauthorized access. -
Highly efficient
Every Tecra W50-A is recognized as an EPEAT Gold Certified eco-friendly product. And because it has an ENERGY STAR qualification, you can rely on the W50-A to balance a mighty performance with superior energy efficiency, day in, day out.
- Dynabook Toshiba Tecra W50-A-115 - 15.6" - Intel Core i7 - 4810MQ - vPro - 32 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (4th Gen) - 4810MQ / 2.8 GHz, up to 3.8 GHz / 6 MB Cache
- Memory
- 32 GB DDR3L (4 x 8 GB)
- Storage
- 256 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro K2100M
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- DualPoint
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell - up to 4.5 hours
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
- Black
- 38.09 cm x 25.39 cm x 3.49 cm
- 2.7 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- International warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i7 (4th Gen) 4810MQ / 2.8 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- Cache
- L3 - 6 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
- RAM
- 32 GB (4 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 4
- Empty Slots
- 0
Storage
- Main Storage
- 256 GB SSD mSATA SATA 3Gb/s
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Video System Features
- NVIDIA CUDA Technology
- Camera
- Resolution
- 2 Megapixel
- Video Resolutions
- 1980 x 1080
- Sound
- Stereo speakers, stereo microphone
- High Definition Audio, DTS Studio Sound
Input
- Keyboard, DualPoint
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Capacity
- 67 Wh
- Run Time
- Up to 4.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 180 Watt, 19 V, 9.5 A
Connections & Expansion
- Slots
- 1 x ExpressCard/54 (1 free)
- VGA , LAN , USB 2.0/eSATA , Headphone/microphone combo jack , DisplayPort , 2 x USB 3.0 , 2 x USB 2.0 , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
- Black
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 2.7 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80%
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
