Product
Toshiba Tecra W50-A-115 Intel Core i7-4810MQ 32GB 256GB SSD 15.6" Windows 7 Professional 64-bit
Quicklinx: 9TMZWS00 Mfr#: PT640E-06403GEN
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
The 39.6 cm (15.6") Tecra W50-A is the ultimate mobile powerhouse. Built to take on the most intensive computing demands, this professional workstation delivers a mighty performance - wherever your business takes you. Driven by powerful Intel quad core processor and fast NVIDIA Quadro graphics, the W50-A handles multiple, graphics-intensive applications and demanding system tasks with absolute ease. From its super responsive SDD drives to the reliable design, extreme performance has never been so portable.
  • Extreme performance on demand
    The Tecra W50-A isn't called a workstation for nothing. Driven by Intel quad core processor, it's a powerhouse of speed and strength that will cut through the heaviest of workloads. So you can rely on an extreme performance, right when you need it. Nothing will get in the way of your workflow as you switch between multiple applications or documents. Even if those applications are graphics-rich and particularly demanding, the dedicated NVIDIA Quadro graphics card with fast GDDR3 memory delivers a dramatically higher performance to accelerate tasks like video editing and creating animations.
  • Smarter drives, faster response
    Some commands should just happen, fast. Boot up, shut down and application start-up. Opening, saving or storing files. None of these should get in the way of a busy professional under pressure to deliver. And with Solid State Drive, the Tecra W50-A really delivers - through a much higher responsiveness that helps your work flow quickly and smoothly. So, just like your workstation, you can zip through essential processes, whizz through system tasks and perform brilliantly.
  • Mighty mobility
    The Tecra W50-A is as mobile as it is mighty, with all the ports and interfaces you need to work flexibly. There's the high-quality Wi-Fi with Bluetooth, so you can always access the important business information you need. And the USB 3.0 ports to transfer your data to other devices at blazing speeds. If you want to share or present your work, it's easy to connect to high-resolution professional displays, using DisplayPort. Or do it wirelessly, using the Intel Wireless Display (WiDi). You can even get faster access to your local network, with Gigabit LAN.
  • Better connected
    With the extra connectivity you get from the docking port, you can make the most of all your peripherals from the comfort of your desk. So it's easy to create a more comfortable and productive working environment. You might want to connect to a high-speed drive to quickly back up your day's work. Or use your printer to create hard copies of your meeting notes. And you can simply add a display if you prefer dual screens when working on multiple projects or documents.
  • Advanced security
    The Tecra W50-A is full of advanced security features to help keep your business-critical data safe. Along with the Trusted Platform Module (TPM), it protects the data on your local storage. From the start, a secure fingerprint reader makes signing on quick and personal to you, while Intel Anti-Theft means your laptop can be locked-down remotely to prevent unauthorized access.
  • Highly efficient
    Every Tecra W50-A is recognized as an EPEAT Gold Certified eco-friendly product. And because it has an ENERGY STAR qualification, you can rely on the W50-A to balance a mighty performance with superior energy efficiency, day in, day out.
Toshiba Tecra W50-A-115 - 15.6" - Core i7 4810MQ - 32 GB RAM - 256 GB SSD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Intel Core i7 (4th Gen) 4810MQ / 2.8 GHz (3.8 GHz) / 6 MB Cache
32 GB DDR3L (4 x 8 GB)
Storage
256 GB - mSATA SSD
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro K2100M
Video Memory
2 GB GDDR5 SDRAM
Input Device
DualPoint
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell - up to 4.5 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, SmartCard reader
38.09 cm x 25.39 cm x 3.49 cm
2.7 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
International warranty - 1 year - carry-in
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel QM87 Express
Platform Technology
Intel vPro Technology
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
RAM
32 GB (4 x 8 GB)
Max RAM Supported
32 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
4
Empty Slots
0
Storage
Main Storage
256 GB SSD - (mSATA) SATA 3Gb/s
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Video System Features
NVIDIA CUDA Technology
Camera
Resolution
2 Megapixel
Video Resolutions
1980 x 1080
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Numeric Keypad
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I217-LM
Wi-Fi CERTIFIED
6-cell Lithium Ion
67 Wh
Run Time
Up to 4.5 hours
AC Adapter
Input
Output
180 Watt, 19 V, 9.5 A
Connections & Expansion
Slots
1 x ExpressCard/54 (1 free)
VGA , LAN , USB 2.0/eSATA , Headphone/microphone combo jack , DisplayPort , 2 x USB 3.0 , 2 x USB 2.0 , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
Case Material
Polycarbonate ABS
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
Power adapter
Localization
2.7 kg
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
9TMZ C2G HDMI to DisplayPort Adapter Converter In Stock £37.28
9TMZ C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.54
9TMZ C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.60
9TMZ C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
9TMZ C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.23
9TMZ C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.14
9TMZ C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.66
9TMZ C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.83
