Toshiba Tecra R850-119 Core i5-2520M 4GB 320GB 15.6" Windows 7 Professional 64 bit Laptop
Quicklinx: 7HNLWS00 Mfr#: PT525E-00C004EN
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 3.0
  • IEEE 802.11n
Thin, light, and durable, the Tecra R850 is the perfect business laptop. Intel processors provide best-in-class performance, while long time battery life keeps you mobile. The robust chassis featuring honeycomb structure underneath the palm rest area and the 3D HDD impact sensor both help keep data secure. A 15.6" non-reflective HD display with LED backlighting provides sharp detail, while a DisplayPort enables connectivity to HD monitors. A 10-digit numeric keypad also makes data input easy.
  • Dependable and durable
    When you're on the move, you need a laptop that can withstand the knocks and bumps that go with the territory. In addition to robust exteriors featuring magnesium alloys chassis and spill-resistant keyboard, the internal airpocket has been designed cushioning and special padding to safeguard the laptop and your data as proof of their durability.
  • Completely connected
    Tecra brings you fast, easy, and super-reliable mobile broadband performance via the integrated Wi-Fi. Other features include Toshiba ConfigFree to connect quickly and easily, as well as diversity antennae which constantly adjust to maintain the best possible connection.
  • Business convenience
    Tecra makes it easier for IT support to monitor, protect, maintain, and upgrade your laptops - resulting in far less downtime.
Dynabook Toshiba Tecra R850-119 - 15.6" - Core i5 2520M - 4 GB RAM - 320 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i5 (2nd Gen) 2520M / 2.5 GHz (3.2 GHz) / 3 MB Cache
4 GB DDR3 (1 x 4 GB)
Storage
320 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight anti-reflective 1366 x 768 / HD
Graphics
Intel HD Graphics 3000
Input Device
DualPoint
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 3.0, Gigabit Ethernet
6-cell - up to 7.5 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
Graphite black, matte black
37.9 cm x 25.2 cm x 2.5 cm
2.5 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
International warranty - 1 year - carry-in
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Chipset
Mobile Intel QM67 Express
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology
RAM
4 GB (1 x 4 GB)
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1333 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
320 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Max Allocated RAM Size
1696 MB
Camera
Resolution
0.3 Megapixel
Sound
Stereo speakers, microphone
Codec
Realtek ALC269Q
High Definition Audio
Audio Features
Output: Toshiba Bass Enhanced Sound System
Input
Keyboard, DualPoint
Numeric Keypad
Spill-resistant
Communications
Wireless
Wireless Controller
Intel Centrino Advanced-N 6230
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
6-cell Lithium Ion
6200 mAh
Run Time
Up to 7.5 hours
AC Adapter
Input
Output
65 Watt, 19 V, 3.42 A
Connections & Expansion
VGA , Microphone input , Headphone output , 2 x USB 2.0 , USB 2.0/eSATA , LAN , Dock , USB 3.0 , DisplayPort
Memory Card Reader
Yes (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, SDHC Card)
Software
Software Included
Drivers & Utilities, Toshiba ConfigFree, Connectivity Doctor, McAfee Internet Security Suite (30 days subscription), Toshiba Supervisor Password Utility, Toshiba Bluetooth Stack, Skype, Toshiba Assist, Windows Live Essentials, ebay, Toshiba Recovery Media Creator, Toshiba Photo Service, Toshiba Bluetooth Monitor, Toshiba Disc Creator, WildTangent Game Console, Toshiba Value Added Package, Chicony Camera Assistant Software, Face Recognition software, Toshiba DVD Player, Bing Toolbar, Amazon, Nero BackItUp & Burn Essentials, Microsoft Office 2010 Starter, Nero 10 Essentials
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard
Localization
2.5 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
