Toshiba Tecra A50-C-17C Intel Core i5-5200U 4GB 500GB 15.6" Windows 7 Professional
Quicklinx: BPL5WS00 Mfr#: PS569E-00R00DEN
  • Core i5
  • Microsoft Windows 7 Professional
  • IEEE 802.11n
  • Bluetooth 4.0
Engineered with Experience
Built on 30 years of experience in manufacturing premium laptops, Toshiba’s Tecra A50-C and your business are the perfect match. The A50-C is designed for long-lasting versatility, while also remaining professional with a slim appearance and subtle, yet distinct design – striking a balance between aesthetic appeal, exterior durability and interior performance.
The Tecra Standard
Fulfil your users’ business requirements with high performance and reliability. The power of an Intel® Core™ CPU up to i7 helps users stay productive from the start of the day right through to its end. And inside, premium components meet the high standard of quality for which the Tecra series is renowned. Intel® HD or Nvidia GT930M graphics ensure a clear view from the 39.6 cm (15.6") HD or Full HD screen, while the optional 256 GB SSD means that your business’ most important documents, data, and media are to hand, in and out of the office.
Connected to your Business
Toshiba's Tecra A50-C enables you to output your onscreen content to two Ultra HD displays using the optional High Speed Replicator III docker. The docker conveniently allows you and your staff to extend the laptop's viewing capacity across external displays with ease - ideal for working on multiple documents at once, or sharing presentations with colleagues.
Reliability from Toshiba
Spill- and drop-resistant, the Tecra A50-C is designed to withstand the challenges of mobile usage, as tested and proven by the device’s H.A.L.T. compliance. Inside, the 3D HDD Impact Sensor protects the HDD in the event of physical damage, keeping your business-critical data intact, while outside, a silent heavy-typer keyboard withstands even the most demanding workloads.
Easy to use, Easy to manage
Manage a single Tecra A50-C, or an entire fleet with ease, thanks to a number of features that enable remote control and network-based management. The integrated high-speed Gigabit LAN facilitates rapid delivery of patches from an SCCM infrastructure, while the WMI-enabled bios allows the same SCCM system to remotely manage and configure all settings. What’s more, the A50-C is protected by McAfee LiveSafe software from the moment the device is turned on.
Environmentally Responsible
Take control of your business’ energy consumption by better managing your power settings with Toshiba’s Eco Utility software, built into the Tecra A50-C. The device is also EPEAT certified, confirming it as eco-friendly, and has qualified for the latest Energy Star rating for its state-of-the-art energy efficiency.
Your Business Toolkit
While the Tecra A50-C is a great standalone business laptop, its benefits can be extended even further with a range of licensed Toshiba accessories. Increase the number of ports and make your A50-C into a connection hub with the Toshiba Dynadock or HSPR III docking station, and support heavier workloads with B2B-specific external storage devices, whether they be HDD, SSD, SD Cards or USB sticks. And for protection throughout the day, Toshiba also offers a range of bags and sleeves – allowing you to tailor the Tecra experience to your users’ exact requirements.
  • Your laptop, your way
    Go to Toshiba Direct and can configure your Tecra A50 laptop anyway way you like, with the specific business-class features you need to perform at your peak.
  • Business-class features - for first-class results
    Don't use everyday technology to get your important work done. Boot up the Tecra A50 laptop, common docking, a dedicated numeric 10-key pad for smoother data entry, HDMI, VGA, eSATA plus USB 3.0 ports, along with Intel AGN or BGN wireless options.
  • Get and give a stellar performance
    With the Tecra A50 laptop, we've cut out all the enterprise-class features you don't need, but kept all the performance you do. Fire up 4th Gen Intel Core processors for multitasking, crunching numbers or staying productive with the latest apps.
  • Built to last
    Shock-absorbing design, unique honeycomb-reinforced chassis and other extras, The Tecra A50 laptop proudly carries the Tecra tradition of durability. It embodies Toshiba's reputation for quality and reliability, thanks to highly accelerated life testing in our factory.
  • Range far and wide
    A longer battery life rating frees you to travel farther and stay productive longer between charges. The Tecra A50 laptop has a removable standard six-cell battery that can easily be swapped out for a high-capacity battery.
Dynabook Toshiba Tecra A50-C-17C - 15.6" - Core i5 5200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i5 (5th Gen) 5200U / 2.2 GHz (2.7 GHz) / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Tile black (keyboard), steel grey with precious hairline
37.9 cm x 25.8 cm x 2.325 cm
2.4 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
DTS Studio Sound
Input
Keyboard, touchpad
Numeric Keypad
Palm Rejection Technology, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi), Wake-on-LAN (WOL)
Wi-Fi CERTIFIED
4-cell Lithium Ion
45 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
2 x USB 2.0 , 2 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Case Material
Aluminum, polycarbonate ABS
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, remote boot control
Power adapter
Localization
2.4 kg
ENERGY STAR Certified
