Toshiba Tecra A40-C-1KF Core i5-6200U 4GB 500GB 14" Win 10 Pro
Quicklinx: CT0ZWS00 Mfr#: PS463E-07U03HEN
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
The Tecra A40-C's optimized dual antenna design ensures you've always got perfect connection - so nothing gets in the way of you accessing, saving and sharing your work. And with a Gigabit LAN port built-in to the laptop, as well as Wi-Fi, you can connect however you want, and stay productive throughout the day and beyond. With a full-size, silent-type keyboard, you can write documents comfortably without disturbing co-workers or family - whether you're at the desk, or at home.
  • Be connected
    The Tecra A40-C's optimised dual antenna design ensures you've always got the best possible connection – so nothing gets in the way of you accessing, saving and sharing your work. And with a Gigabit LAN port built-in to the laptop, as well as the latest Intel Wi-Fi and optional LTE, you can connect however you want, and stay productive throughout the day and beyond.
  • Designed for productivity
    With a full-size, silent-type keyboard, you can write documents comfortably without disturbing co-workers or family – whether you're at the desk, or at home. There's even an optional Accupoint input that keeps you in control at all times. What's more, the Tecra A40-C offers an optional backlit keyboard, alongside a non-reflective screen, so you can work comfortably in both bright sunlight and complete darkness.
  • The instant office
    The Tecra A40-C has a range of full-size ports built in, making it a fully-functional standalone PC in any setting. And when combined with the High Speed Port Replicator III docker, it instantly transforms your desk into a multi-featured office workstation. That means you can take advantage of two digital video outs, as well as four additional USB 3.0, and two more USB 2.0 ports, amongst others. This combination makes the Tecra A40-C the perfect replacement for a desktop, while its easy-to-carry chassis makes it your ideal laptop too.
  • The model employee
    Like every PC in the Tecra and Portégé range, the Tecra A40-C fits seamlessly into your existing IT infrastructure, straight out of the box. That's thanks to its common software image, docking solution and AC adapter, as well as its widely-compatible driver support. The Tecra A40-C is ready for advanced manageability too – with full support for Intel AMT and SCCM, and a common WMI interface. With these features, you get a return on your investment from the moment the Tecra A40-C is switched on, to the end of its lifespan.
  • Robust, secure, value-packed
    High levels of reliability don't just keep employees more productive – they keep total cost of ownership low too. That's why the Tecra A40-C has been built with the highest quality components. And with Toshiba's 30 years of laptop development experience, you can count on super-low failure rates that keep your business moving. The Tecra A40-C has even been H.A.L.T (Highly Accelerated Life Tested) by independent test institute TÜV Rheinland, so you can be confident it can handle the bumps and strains that come with everyday productivity.
  • All the accessories you need
    As well as the High Speed Port Replicator III docker, the Tecra A40-C is available with a range of accessories* that make agile working simpler. With everything from USB sticks to SD cards, you can count on quick, simple data transfer, whatever format your files are in. And with stylish laptop bags and sleeves, you can protect your PC on the move too. *Accessories sold separately.
  • Certified Eco-friendly
    Take control of your environmental impact with Toshiba's EPEAT certified Tecra A40-C, complete with built-in Eco Utility. Quickly and easily customise your computer settings to maximise power efficiency, minimise energy consumption, and reduce the impact your work has on the planet. You can even take part in our Carbon Zero* programme, and offset the entire carbon footprint of your laptop. *Carbon Zero available in UK only.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Tecra A40-C-1KF - 14" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 8 hours
Accelerometer
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Steel grey metallic, tile black (keyboard)
34.01 cm x 24.41 cm x 2.38 cm
1.75 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - carry-in
Regional Warranty Exceptions
United Kingdom, Ireland - 1 year pick-up and return
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, touchpad
Multi-gesture touch pad, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
LAN , HDMI , Headphone/microphone combo jack , 2 x USB 3.0 , VGA , Dock , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
Case Material
Magnesium alloy
Integrated Options
Accelerometer
Dockable
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Power adapter
TUV Rheinland
Localization
1.75 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
