Brand
Toshiba TEC B EV4D Mono Direct Thermal Label Printer
Quicklinx: 8C6TWS00 Mfr#: B-EV4D-GS14-QM-R
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
£213.11 ex VAT
£255.73 inc VAT
For fast, on-demand labeling and ticketing direct from your desktop, look no further than the trustworthy B-EV4 range from Toshiba. With market-leading features, exceptional build quality and reliability produce professional labels quickly and easily at the touch of a button.
Toshiba TEC B-EV4D - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
2.3 kg
Max Media Size
Roll (11.2 cm)
Min Media Size (Custom)
25.4 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 127 mm/sec - monochrome
Max Resolution (B&W)
203 dpi
Parallel, USB, LAN, serial
Barcodes
EAN/JAN, Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, NW-7, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Postnet, PDF417, MSI-Plessey, Data Matrix, ITF, Kix (Netherlands) Post, Plessey, RM4SCC, MSI-3, GS1 DataBar Omnidirectional
Media Type
Labels, continuous forms, transparency film
Fonts
Helsinki, Courier, Letter Gothic, Prestige Elite, Times New Roman, Kanji, Presentation, OCR-A, OCR-B
Self-strip
AC 120/230 V
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista
19.8 cm x 26.2 cm x 17 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 127 mm/sec - monochrome - 203 dpi
Wired
203 dpi
Fonts
Self-strip
Fonts Included
2 x outline , 20 x bitmapped
Barcodes
Card Reader
Supported Flash Memory Cards
SD Memory Card
Media Handling
Media Type
Max Media Size
Roll (11.2 cm)
25.4 mm
112 mm
Max Printing Width
108 mm
Max Printing Length
995 mm
Media Thickness Range
0.06 mm - 0.19 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm, 38.1 mm
Media Feeders
1 x manual - 1 roll
1 x RS-232 , 1 x parallel , 1 x USB , 1 x LAN
Paper sensor
RoHS
Power supply - internal
AC 120/230 V
Frequency Required
50/60 Hz
70.3 Watt
Power Consumption Stand by / Sleep
2.18 Watt
5 °C
25 - 85%
19.8 cm
26.2 cm
17 cm
2.3 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (11.2 cm)
Brand: Toshiba
