Give your business an edge with an enterprise-class laptop built for small- or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R40 will help meet all your computing needs without putting a big dent in your bottom line. Powered by a fast and smooth processor you will be able to more effectively manage your workload wherever the day takes you. Plus, enjoy added security knowing that your Satellite Pro R40 is extra strong thanks to its durable design. Imagine how much more pleasant those spreadsheets will be on a brilliant 15.6" diagonal HD display. The keyboard with a numeric keypad will make multi-tasking more convenient, plus, there is a host of other components to be effective - like plenty of memory a built-in optical drive, a huge storage, business ports and much more.
Built for business
Give your business an edge with an enterprise-class laptop built for small- or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R40 will help meet all your computing needs without putting a big dent in your bottom line. -
Power and strength
Powered by a fast and smooth processor you will be able to more effectively manage your workload wherever the day takes you. Plus, enjoy added security knowing that your Satellite Pro R40 is extra strong thanks to its durable design. -
Equipped for success
Imagine how much more pleasant those spreadsheets will be on a brilliant 15.6" diagonal HD display. The keyboard with a numeric keypad will make multi-tasking more convenient, plus, there is a host of other components to be effective - like plenty of memory, a built-in optical drive, a huge storage, business ports and much more.
- Dynabook Toshiba Satellite Pro R40-C-106 - 14" - Intel Core i3 - 6100U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i3 (6th Gen) - 6100U / 2.3 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Graphite black, black (keyboard)
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.75 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100U / 2.3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 8 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Resolution
- 0.9 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Security
- Security lock slot (cable lock sold separately), administrator password, system password
- Included Accessories
- Power adapter
- Localization
- 1.75 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
