Toshiba Satellite Pro A50-C-1GD i5-6200U 4GB 500GB 15.6" Win10
Quicklinx: BW0DWS00 Mfr#: PS575E-012001EN
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
Every professional needs a laptop that will help speed through business, not slow it down. That's why the 39.6 cm (15.6") Satellite Pro A50 from Toshiba offers nothing less than multi-tasking at its best. The next generation in an established line of professional Satellite Pro laptops, it uses a high-capacity processor to power through the busiest or most varied of workloads. And with a durable design plus security features built in, you can rely on it to protect your data too.
  • Speed through multiple tasks
    Busy professionals need to multi-task - and their business laptop needs to help them do it. With high-capacity processor, the Satellite Pro A50 lets you power through your workload with ease. So you can just focus on the tasks at hand, even when working with multiple applications or different documents at the same time, to get the job done.
  • Faster response to every command
    Your laptop shouldn't hold you back. When you want it to do something, you expect a quick reaction. And you can expect nothing less than the fastest response from the Satellite Pro A50. There's no time delay or waiting around. So as soon as you want to boot up, shut down, or open, save and store your files - you can.
  • More connections, more freedom
    With the flexibility of high-quality wireless, wired and video connections, you have the freedom to work in more ways and places. You can transfer data to other devices, using USB 2.0. Or do it up to 10 times faster with the USB 3.0 ports. It's easy to send large files via Bluetooth, and share your content in professional HD brilliance on a high-resolution display, using HDMI. Even do it wirelessly, with the Intel Wireless Display (WiDi). And if you need fast access to your local network, there's Gigabit LAN too.
  • Keep everyday devices in easy reach
    No matter how and where you work, it's important to keep your everyday business tools to hand. Plus you gain extra ports for your printer or any other peripherals that you use daily.
  • Safe and secure
    The Satellite Pro A50 was designed to protect your business-critical information without impacting on your performance. With the Trusted Platform Module (TPM), they safeguard the critical data on your local storage.
Dynabook Toshiba Satellite Pro A50-C-1GD - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 8 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
Graphite black, black (keyboard)
37.9 cm x 25.8 cm x 2.395 cm
2.1 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Windows 10 Home 64-bit Edition (preloaded)
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
DTS Sound
Input
Keyboard, touchpad
Numeric Keypad
Palm Rejection Technology, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
2 x USB 3.0 , LAN , HDMI , Headphone/microphone combo jack , VGA , 2 x USB 2.0
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription)
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, 3D Accelerator
Power adapter
Localization
2.1 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
