Higher Performance When You Need It Most
Intel® Turbo Boost Technology 2.01 accelerates processor and graphics performance by increasing the operating frequency when operating below specification limits. The maximum frequency varies depending on workload, hardware, software, and overall system configuration.
Protect Your Identity and Business
Intel® Identity Protection Technology (Intel® IPT) protects enterprises from being penetrated by stolen credentials and online user account access with an added layer of hardware-based security and authentication as well as a multifactor authentication framework to manage different authentication methods.
Solutions to Help You Focus on Your Small Business
Intel® Small Business Advantage (Intel® SBA) helps small businesses without a managed network manage security and productivity issues. This solution helps maintain and protect PCs automatically so that you can focus on running your business.
- Dynabook Toshiba Satellite Pro A40-C-109 - 14" - Core i5 6200U - 500 GB HDD
- Product Type
- Notebook
- Processor
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz)
- Memory
- DDR3L
- Storage
- 500 GB HDD
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Networking
- 802.11ac, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.75 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- Notebook
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
Storage
- Main Storage
- 500 GB HDD
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-reflective
Audio & Video
- Graphics Processor
- Sound
- Stereo speakers
- DTS Studio Sound
Input
- Keyboard
- Palm Rejection Technology
Communications
- Wireless
- 802.11ac
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V
Connections & Expansion
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
- Security
- Localization
- 1.75 kg
- ENERGY STAR Certified
- 1-year warranty
