With the Satellite Pro A40-C's full-size keyboard, you can type documents or communicate with colleagues silently and precisely. And when it comes to reviewing creative work, the full-size HD display delivers you vibrant clarity, even in bright sunlight - so you won't need an external monitor. The easy-to-carry Satellite Pro A40-C makes working on the move just as productive as being at your desk. Connect quickly and easily wherever you are using built-in ultimate Intel Wi-Fi. With a range of full-size ports and Intel WiDi, you can connect, collect, share and store information with ease in any business situation - whether you're presenting at a client's office, or working in the library. Designed to be super-accessible in the right hands, and super-secure in the wrong ones, the Satellite Pro A40-C combines outstanding usability with exceptional security features.
Desk-based excellence
With the Satellite Pro A40-C's full-size keyboard, you can type documents or communicate with colleagues silently and precisely. And when it comes to reviewing creative work, the full-size, HD display delivers you vibrant clarity, even in bright sunlight - so you won't need an external monitor. -
Mobile brilliance
The easy-to-carry Satellite Pro A40-C makes working on the move just as productive as being at your desk. Connect quickly and easily wherever you are using built-in ultimate Intel Wi-Fi. With a range of full-size ports and Intel WiDi, you can connect, collect, share and store information with ease in any business situation - whether you're presenting at a client's office, or working in the library. -
Security business needs
- Dynabook Toshiba Satellite Pro A40-C-108 - 14" - Intel Core i3 - 6100M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i3 (6th Gen) - 6100M / 2.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Graphite black, black (keyboard)
- 34.01 cm x 24.41 cm x 2.38 cm
- 1.75 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100M / 2.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Security
- Security lock slot (cable lock sold separately), administrator password, system password
- Included Accessories
- Power adapter
- Localization
- 1.75 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
