Stay connected, stay productive - be mobile. Work and learn wherever you are, with the 13.3" Satellite Pro A30-C - the mobile laptop that never compromises on performance, connectivity, or durability. Long battery life makes the A30-C ready to replace the paper notebook as your go-to learning tool.
Learn wherever you are
The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its high-quality HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going for a long time, you're never interrupted by the need to find a socket and plug in. -
The PC you can count on
Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will never let you down. -
Connect to knowledge
The Satellite Pro A30-C comes with a range of dongle-free connectivity possibilities - including HDMI, three USB 3.0 ports for saving and sharing content at speed, and premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features an excellent Full HD webcam. -
Perform to achieve
Although the Satellite Pro A30-C is super-mobile, it never compromises on performance. That's because it's built with advanced internal components like the powerful processor. With the A30-C, you can get things done as fast as you need to - making it perfect for working between meetings, or getting your essay done as your deadline approaches. -
Professional levels of security
Whether it's your dissertation or your business's critical data, there are some things you don't want getting into the wrong hands. With the Satellite Pro A30-C, you can rest assured thanks to its TPM (Trusted Platform Module). That way, you're protected from the first time you press the power button.
- Dynabook Toshiba Satellite Pro A30-C-11L - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 13 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black (keyboard), black magnesium with precious hairline
- 31.6 cm x 22.9 cm x 2.24 cm
- 1.5 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD SATA
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Security
- Security lock slot (cable lock sold separately), administrator password, system password
- Included Accessories
- Power adapter
- Localization
- 1.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
