Toshiba Satellite Pro A30-C-10R i3-6100U 4GB 500GB 13.3" Win 7 Pro
Quicklinx: BVZZWS00 Mfr#: PT361E-003001EN
  • Core i3
  • Microsoft Windows 7 Professional
  • Bluetooth 4.0
  • IEEE 802.11n
The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its non-reflective HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going all day, you're never interrupted by the need to find a socket and plug in. Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will not let you down. The Satellite Pro A30-C comes with a range of dongle-free connectivity capabilities - including HDMI for making presentations, three USB 3.0 ports for saving and sharing content at speed, and Intel premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features a full-size SD card slot. These features are complimented by a Full HD webcam and noise canceling dual mics that make chatting via Skype easier than ever. Although the Satellite Pro A30-C is super-mobile, it never compromises on performance. That's because it's built with efficient components. With the A30-C, you can get things done as fast as you need to - making it perfect for working between meetings, or getting your essay done as your deadline approaches.
  • Learn wherever you are
  • PC you can count on
  • Connect to knowledge
  • Perform to achieve
Dynabook Toshiba Satellite Pro A30-C-10R - 13.3" - Intel Core i3 - 6100M - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i3 (6th Gen) - 6100M / 2.1 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
13.3" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 9.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
Black (keyboard), black magnesium with precious hairline
31.6 cm x 22.9 cm x 2.24 cm
1.5 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - carry-in
Notebook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6100M / 2.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, stereo microphone
DTS Studio Sound
Input
Keyboard, touchpad
Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 9.5 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Security
Security lock slot (cable lock sold separately), administrator password, system password
Power adapter
Localization
1.5 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
