The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its non-reflective HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going all day, you're never interrupted by the need to find a socket and plug in. Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will not let you down. The Satellite Pro A30-C comes with a range of dongle-free connectivity capabilities - including HDMI for making presentations, three USB 3.0 ports for saving and sharing content at speed, and Intel premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features a full-size SD card slot. These features are complimented by a Full HD webcam and noise canceling dual mics that make chatting via Skype easier than ever. Although the Satellite Pro A30-C is super-mobile, it never compromises on performance. That's because it's built with efficient components. With the A30-C, you can get things done as fast as you need to - making it perfect for working between meetings, or getting your essay done as your deadline approaches.
Learn wherever you are
The Satellite Pro A30-C's compact form fits into any bag comfortably, so it's ideal to carry from place to place. But that's not all that makes it perfect for learning and working on the move - with its non-reflective HD display, you can work anywhere, even in bright sunlight. And with a battery life that will keep going all day, you're never interrupted by the need to find a socket and plug in. -
PC you can count on
Designed to withstand the everyday bumps and strains of agile learning, the Satellite Pro A30-C's lightweight but robust magnesium chassis will not let you down. -
Connect to knowledge
The Satellite Pro A30-C comes with a range of dongle-free connectivity capabilities - including HDMI for making presentations, three USB 3.0 ports for saving and sharing content at speed, and Intel premium Wi-Fi performance - so you can connect and collect learning materials hassle-free. The A30-C also features a full-size SD card slot. These features are complimented by a Full HD webcam and noise canceling dual mics that make chatting via Skype easier than ever. -
Perform to achieve
- Dynabook Toshiba Satellite Pro A30-C-10R - 13.3" - Intel Core i3 - 6100M - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i3 (6th Gen) - 6100M / 2.1 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 9.5 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Black (keyboard), black magnesium with precious hairline
- 31.6 cm x 22.9 cm x 2.24 cm
- 1.5 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- EMEA warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence (preloaded)
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100M / 2.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Built-in numeric keyboard, multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 9.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , LAN , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Security
- Security lock slot (cable lock sold separately), administrator password, system password
- Included Accessories
- Power adapter
- Localization
- 1.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
