Toshiba Sat Pro R50-C-17C Core i5-6200U 4GB 128GB SSD 15.6" Win 10 Pro
Quicklinx: DFD0WS00 Mfr#: PS571E-0C306NEN
Display Size: 15.6in
Processor Model: I5-6200U
Operating System: Windows 10 Home
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 128GB
  • Core i5
  • IEEE 802.11n
Sorry but this product has been discontinued.
View used stock
Give your business an edge with this enterprise-class laptop built for small or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R50 will meet all your computing needs without putting a big dent in your bottom line. Powered by the powerful processor, you will be able to effectively manage your workload wherever the day takes you.
  • Built for business
    Give your business an edge with an enterprise-class laptop built for small or medium-sized businesses. The slim, smart and feature-rich Satellite Pro R50 will help meet all your computing needs without putting a big dent in your bottom line.
  • Power & strength
    Powered by the powerful processor, you will be able to manage your workload more effectively, wherever the day takes you. Plus, enjoy added security knowing that your Satellite Pro R50 is extra strong thanks to its rigorously tested durable design.
  • Equipped for success
    Imagine how much more pleasant those spreadsheets will be on a brilliant HD display.
  • Security & peace of mind
    Toshiba EasyGuard technology helps keep the Satellite Pro R50 secure, protected, connected and optimized. A full suite of safeguard features helps keep your laptop shielded, constantly mobile and your data secure, giving you the time and peace of mind to focus on running your business.
Dynabook Toshiba Satellite Pro R50-C-17C - 15.6" - Core i5 6200U - 4 GB RAM - 128 GB SSD
Notebook
Operating System
Windows 10 Home
Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
128 GB SSD
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
4-cell - up to 8 hours
3D sensor
Security
Trusted Platform Module (TPM 2.0) Security Chip
Graphite black
37.9 cm x 25.8 cm x 2.395 cm
2.1 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - pick-up and return
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800 - 1600 MHz
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - HD
Sound
Stereo speakers, microphone
DTS Sound
Input
Keyboard, touchpad
Numeric Keypad
Multi-gesture touch pad, Palm Rejection Technology
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 8 hours
AC Adapter
Input
AC 120/230 V
Output
19 V, 2.37 A
Connections & Expansion
LAN , VGA , HDMI
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription)
Graphite black
Integrated Options
3D sensor
Security
Administrator password, system password, hard drive password
Theft/Intrusion Protection
Power adapter
Localization
2.1 kg
ENERGY STAR Certified
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DFD0 040870
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £360.22
Ref: DFD0 040871
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: Intel HD Graphics 520
Hard Drive Type: SSD
Type: Laptop
Brand: Toshiba
Stock Status: Clearance
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
