Your basket is empty
Toshiba Power Bundle - Standard (2 pin)
Quicklinx: BXF7WS00 Mfr#: PA5178U-2PWR
Stay mobile with Genuine Toshiba Power Adapters.
  • AC Adaptor 65W/19V, 4.75A - 2-pin
  • UK power cord
  • EU power cord
  • Compatible with Satellite Pro C70, Portégé R30, Satellite Pro C50-A-1K9, Satellite Pro C50-A-17H
Toshiba - Power Bundle - power adapter - 65 Watt
Power adapter - external
United Kingdom, Europe
Output Voltage
19 V
Power Capacity
65 Watt
Input Connectors
1 x power 2-pole
Portégé Z30, Z30t; Satellite C55, C55D, C70, C70D, L50, L50D, L70, P50, P50t, S50, Z30; Satellite Pro C70, R50; Satellite Radius 14; 15; Tecra A50, Z40, Z50
Input Connectors
1 x power 2-pole
Output Voltage
19 V
Power Capacity
65 Watt
2 x power cable - external
Toshiba Portégé Z30-B-12J, Z30-C-13G, Z30-C-16J, Z30-C-16K, Z30-C-16L, Z30-C-16N, Z30-C-16P, Z30-C-190, Z30-C-191, Z30-C-1C9, Z30-C-1EK, Z30-C-1EL, Z30-C-1EM, Z30-C-1EN, Z30t-C-110 , Toshiba Satellite C55-C-134, C55-C-136, C55-C-14F, C55-C-172, C55-C-173, C55-C-18G, C55-C-19P, C55-C-1DW, C55-C-1E7, C55-C-1G1, C55-C-1G7, C55-C-1J0, C55-C-1JE, C55-C-1JH, C55-C-1JL, C55-C-1JM, C55-C-1KR, C55-C-1KT, C55-C-1L9, C55-C-1LJ, C55-C-1LV, C55-C-1NE, C55-C-1NZ, C55-C-1P3, C55-C-1P6, C55-C-1PN, C55-C-1PW, C55-C-1Q1, C55D-C-11F, C55D-C-15P, C55D-C-163, C55D-C-166, C55D-C-169, C55D-C-16F, C55D-C-16G, C55D-C-16H, C70-C-165, C70-C-167, C70-C-17L, C70-C-181, C70-C-18P, C70-C-190, C70-C-1CK, C70-C-1CN, C70-C-1CP, C70-C-1D4, C70-C-1D5, C70-C-1D8, C70-C-1DG, C70-C-1DV, C70-C-1E0, C70-C-1E2, C70-C-1E7, C70-C-1EN, C70-C-1EQ, C70-C-1ER, C70-C-1FF, C70-C-1G4, C70-C-1G7, C70D-B-34U, C70D-B-34W, L50-B-163, L50-B-1VU, L50-B-1X4, L50-B-1XE, L50-B-1XF, L50-B-1XM, L50-B-2CV, L50-B-2GE, L50-C-116, L50-C-15E, L50-C-1C8, L50-C-1JJ, L50-C-1K4, L50-C-1KP, L50-C-1KX, L50-C-1RP, L50-C-1VG, L50-C-1VH, L50-C-1VJ, L50-C-1VU, L50-C-1VZ, L50-C-1WE, L50-C-1Z8, L50-C-1ZG, L50-C-1ZQ, L50-C-200, L50-C-201, L50-C-20W, L50-C-20X, L50-C-21G, L50-C-21H, L50-C-21J, L50-C-21K, L50-C-22X, L50-C-230, L50-C-241, L50-C-242, L50-C-243, L50-C-24Q, L50-C-24W, L50-C-24X, L50-C-24Z, L50-C-250, L50-C-251, L50-C-25H, L50-C-25Q, L50-C-275, L50-C-27N, L50-C-27P, L50-C-27Q, L50-C-27R, L50-C-2C3, L50-C-2C5, L50-C-2C6, L50-C-2C7, L50D-C-18U, L50D-C-18V, L50D-C-196, L50D-C-19U, L70-C-134, L70-C-13U, P50-C-14J, P50-C-16R, P50-C-179, P50-C-17C, P50-C-17J, P50-C-18F, P50-C-18N, P50t-C-103, Z30-B-157, Z30-B-158, Z30-B-15M , Toshiba Satellite Pro C70-C-14R, C70-C-19E, C70-C-19Q, C70-C-1DN, C70-C-1FT, C70-C-1FX, R50-C-135, R50-C-136 , Toshiba Satellite Radius 14 L40W-C-10R, L40W-C-10V, L40W-C-10Z, L40W-C-115 , Toshiba Satellite Radius 15 P50W-C-10J , Toshiba Tecra Z40-B-144, Z40-B-150
