Toshiba Portege Z30-C-16L Core i7-6500U 8GB 256GB 13.3" Windows 10 Pro 64-bit
Quicklinx: D6CZWS00 Mfr#: PT263E-0PN04MEN
Display Size: 13.3in
Processor Model: I7-6500U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i7
  • IEEE 802.11n
  • Bluetooth 4.0
More than 50 in stock
£1,073.50 ex VAT
£1,288.20 inc VAT
The Portégé Z30-C was made to move. Light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours of battery life on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting.
  • Light for business anywhere
    The Portégé Z30-C was made to move. Light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting. So it's really convenient to type emails or create documents, in or out of the office - even in dimly lit conditions.
  • Power and performance, without compromise
    With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot to the minute you shut down. There's no compromise, so you can run all of your business applications with ease.
  • Better connected on the move
    The Portégé Z30-C is packed with mobile flexibility. You can transfer data to other devices much faster. Or share your presentations in high-resolution brilliance with HDMI. Gigabit LAN also allows fast access to your local network. You can be more productive anywhere.
  • You can depend on it
    The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life. With its light yet strong magnesium chassis, the Portégé Z30-C is robust enough to withstand ultra-mobile business, so you can be sure of a higher return on your investment.
Dynabook Toshiba Portégé Z30-C-16L - 13.3" - Core i7 6500U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) 6500U / 2.5 GHz (3.1 GHz) / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
DualPoint, ClickPad
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 11 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Steel gray metallic, matte black keyboard
31.6 cm x 22.7 cm x 1.79 cm
1.2 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, DualPoint, ClickPad
Keyboard Backlight
Multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell Lithium Ion
Run Time
Up to 11 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
2 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft Office 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription)
Case Material
Magnesium alloy
Dockable
Security
Administrator password, system password
Theft/Intrusion Protection
Power adapter
Localization
1.2 kg
ENERGY STAR Certified
Software applications
Toshiba Portege Z30-C-16L Core i7-6500U 8GB 256GB 13.3 Bundle deal on Toshiba Portege Z30-C-16L Core i7-6500U 8GB 256GB 13.3" Windows 10 Pro 64-bit
£1,255.67
saving £8.33
£1,165.04
Optical Storage: None
Graphics: Intel HD Graphics 520
Hard Drive Type: SSD
Type: Laptop
Brand: Toshiba
Price Range Ex VAT: 1000 - 1500
