Ultra-light for business anywhere
The Portégé Z30-C was made to move. Ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office - even in dimly lit conditions, using the illuminated keyboard. -
Power and performance, without compromise
With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease. -
Better connected on the move
The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster. Or share your presentations in high-resolution brilliance with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere. -
You can depend on it
The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards. With its light yet strong magnesium chassis, the Portégé Z30-C is robust enough to withstand ultra-mobile business, so you can be sure of a higher return on your investment.
- Dynabook Toshiba Portégé Z30-C-156 - 13.3" - Intel Core i7 - 6500U - 16 GB RAM - 512 GB SSD - 4G LTE
- Product Type
- Ultrabook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
- Memory
- 16 GB DDR3L (2 x 8 GB)
- Storage
- 512 GB SSD
- Display
- 13.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 520
- Input Device
- DualPoint
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- 4-cell - up to 11 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Steel gray metallic, matte black keyboard
- 31.6 cm x 22.7 cm x 1.79 cm
- 1.2 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- International warranty - 1 year - carry-in
- Product Type
- Ultrabook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6500U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD SATA
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, two microphones
- DTS Studio Sound
Input
- Keyboard, DualPoint
- Multi-touch clickpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GSM, GPRS, EDGE, HSPA+, LTE
- Controller
- Sierra Wireless AirPrime EM7305
Navigation
- Receiver
- A-GPS
- Technology
- 4-cell lithium polymer
- Run Time
- Up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Case Material
- Magnesium alloy
- Dockable
- Security
- Security lock slot (cable lock sold separately), administrator password, system password, USB Sleep-and-charge ports
- Included Accessories
- Power adapter
- Localization
- 1.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
