Toshiba Portege Z30-C-155 Skylake i7-6500U 8GB 256GB SSD 13.3" Win 7
Quicklinx: C5DQWS00 Mfr#: PT263E-0L803MEN
  • Core i7
  • Microsoft Windows 7 Professional
  • IEEE 802.11n
  • Bluetooth 4.0
The Portégé Z30-C was made to move. Ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours of battery life on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting.
With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster. The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards.
  • Ultra-light for business anywhere
    The Portégé Z30-C was made to move. Ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get many hours on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the non-reflective screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office - even in dimly lit conditions, using the illuminated keyboard.
  • Power and performance, without compromise
    With the advanced processor your laptop has all the power you need to multitask on the move or in the office. The Portégé Z30-C delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
  • Better connected on the move
    The Portégé Z30-C is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster. Or share your presentations in high-resolution brilliance with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere.
  • You can depend on it
    The ultra-durable Portégé Z30-C was designed to withstand the pressures of professional life and meet Toshiba's quality standards. With its light yet strong magnesium chassis, the Portégé Z30-C is robust enough to withstand ultra-mobile business, so you can be sure of a higher return on your investment.
Dynabook Toshiba Portégé Z30-C-155 - 13.3" - Intel Core i7 - 6500U - 8 GB RAM - 256 GB SSD
Ultrabook
Operating System
Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Intel Core i7 (6th Gen) - 6500U / 2.5 GHz, up to 3.1 GHz / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Input Device
DualPoint
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell - up to 11 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Steel gray metallic, matte black keyboard
31.6 cm x 22.7 cm x 1.79 cm
1.2 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
International warranty - 1 year - carry-in
Ultrabook
Operating System
Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6500U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD SATA
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD
Resolution
2 Megapixel
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Multi-touch clickpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8260
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
4-cell lithium polymer
Run Time
Up to 11 hours
AC Adapter
Input
Output
19 V, 2.37 A
Connections & Expansion
Interfaces Details
3 x USB 3.0 , HDMI , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
Software Included
Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
Case Material
Magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, USB Sleep-and-charge ports
Power adapter
Localization
1.2 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
