Toshiba Portege Z30-A-1D6 Intel Core i7-4600U 8GB 256GB SSD 13.3" Windows 7 Professional
Quicklinx: 9M5SWS00 Mfr#: PT241E-01H06UEN
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
With an ultra-thin, premium design that travels light and is professional through and through, the high-performance 33.8 cm (13.3") Toshiba Portégé Z30-A was made to keep business moving. A long-lasting battery, full-size ports and Intel Core processor for Ultrabook help you power through the working day. And because the Portégé Z30-A comes with high-level security and manageability technologies in an ultra-durable chassis, your data will be protected too. High performance goes ultra-mobile, with the Portégé Z30-A.
  • Ultra-light for business anywhere
    The Portégé Z30-A was made to move. Starting at an ultra-light and highly robust, it's the perfect companion to take on your business travels. Even without an extended battery, you get a long-lasting time on a single charge. And if you're out and about in direct sunlight, you won't see any glare on the 33.8 cm (13.3") non-reflective HD screen with LED backlighting. So it's really convenient to type emails or create documents, in or out the office - even in dimly lit conditions, using the illuminated keyboard.
  • Power and performance, without compromise
    With Intel Core processor, your laptop has all the power you need to multitask on the move or in the office. And with a high-performance SSD inside, the Portégé Z30-A delivers faster speeds and higher responsiveness from the second you boot-up to the minute you shut-down. There's no compromise, so you can run all of your business applications with ease.
  • Better connected on the move
    The Portégé Z30-A is packed with mobile flexibility - and because all ports are full-size, you won't need any special adapters either. You can transfer data to other devices much faster, using three of the latest USB 3.0 ports. Or share your presentations in high-resolution brilliance, with HDMI. Gigabit LAN also allows fast access to your local network, while support for LTE gives you the freedom to work wirelessly. So you can be more productive anywhere.
  • Secure and easy to manage
    The Z30-A is built for business, so comes loaded with tried-and-tested security and management features. There's the self-encrypted drives and Trusted Platform Module (TPM) to safeguard the critical data on your local storage. And even if your Z30-A needs to be updated, the IT department can do it at any time, with Intel Active Management Technology (AMT). The standard fingerprint reader makes it easy and secure to log on to your PC too.
  • Synergy across devices
    The Portégé Z30-A shares many features with the business line-up from Toshiba, to ensure consistency across your company. So you can easily access all of your peripherals using a wide range of ports, with the common docking station. The Z30-A also comes with dongle-free connectivity in the form of HDMI, RGB, Gigabit LAN and three USB 3.0 ports for added convenience and flexibility.
Dynabook Toshiba Portégé Z30-A-1D6 - 13.3" - Intel Core i7 - 4600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE
Ultrabook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Platform Technology
Intel vPro Platform
Intel Core i7 (4th Gen) - 4600U / 2.1 GHz, up to 3.3 GHz / 4 MB Cache
8 GB DDR3L (1 x 8 GB)
Storage
256 GB SSD
Display
13.3" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
DualPoint
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
Wireless Broadband (WWAN)
4G LTE
4-cell - up to 12 hours
Dockable
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
Steel gray metallic, matte black keyboard
31.6 cm x 22.7 cm x 1.79 cm
1.2 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Ultrabook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Processor / Chipset
CPU
Intel Core i7 (4th Gen) 4600U / 2.1 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Platform Technology
Intel vPro Platform
Enhanced SpeedStep technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD mSATA SATA 3Gb/s
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HighBrightness, anti-reflective
Audio & Video
Graphics Processor
Camera
Resolution
2 Megapixel
Video Resolutions
1980 x 1080
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, DualPoint
Keyboard Backlight
Spill-resistant, multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Intel Wireless Display (WiDi)
Wi-Fi CERTIFIED
Generation
4G
GSM, GPRS, EDGE, HSPA+, LTE
Controller
Sierra Wireless AirPrime EM7305
Navigation
Receiver
A-GPS
4-cell lithium polymer
52 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
VGA , LAN , HDMI , Headphone/microphone combo jack , 3 x USB 3.0 , Dock
Memory Card Reader
Yes (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
McAfee Internet Security Suite (30 days subscription), Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, Windows 8.1 Pro 64-bit (DVD)
Case Material
Magnesium alloy
Dockable
Security
Security lock slot (cable lock sold separately), administrator password, system password, hard drive password, remote boot control, wake on LAN, Toshiba EasyGuard, Intel Active Management Technology (iAMT), USB Sleep-and-charge ports
Power adapter
Localization
1.2 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
20 - 80%
9M5S C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
