Toshiba Portege X30-D-10V Core i5 7200U 8GB 256GB Windows 10 Pro 64-bit
Quicklinx: D6BHWS00 Mfr#: PT272E-00S00TEN
  • Core i5
  • IEEE 802.11n
The Portégé X30-D, thin and lightweight, powers through your workload with the excellent CPU, and doesn't overheat, thanks to Toshiba Hybrid Air cooling technology - so everything runs fast, and runs smoothly, even in a sleek and light chassis.
  • Made with pride
    The Portégé X30-D, thin and lightweight, powers through your workload with the excellent CPU, and doesn't overheat, thanks to Toshiba Hybrid Air cooling technology - so everything runs fast and runs smoothly, even in a sleek and light chassis.
  • Security, assured
    The security features you need make the Portégé X30-D the device you can trust. Built on the Toshiba unique in-house BIOS, a two-factor authentication and built-in fingerprint reader is added, a magnesium chassis and a slot for the cable lock for physical security.
  • Productivity unleashed
    Streamlined design doesn't mean throttled-back performance. Under the covers in this honeycomb-structured magnesium design you will find the powerful processor, twin USB Type C Thunderbolt 3 enabled ports for extendable connectivity, however you work - plus advacned memory and and PCIe hard drives for blistering performance. Alongside the hardware, support for PXE, vPro, SCCM, and WMI commands makes managing your laptop - and your workload - easy.
  • Content, that fills a room
    For the meetings, that matter, the Portégé X30-D is equipped with the hardware to do your content and media justice. Harman/Kardon speakers with DTS Sound produce crisp, clear music or video and audio, that really fills a meeting room, and the HDMI port means you can share on-screen content on a larger display or TV. Finally, dual microphones make conferencing and collaborating or using voice-enabled features easy and effective.
Dynabook Toshiba Portégé X30-D-10V - 13.3" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
8 GB DDR4
Storage
256 GB SSD
Display
13.3" 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
AccuPoint, SecurePad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell - up to 14.5 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Onyx blue with hairline
31.6 cm x 22.7 cm x 1.64 cm
1.05 kg
Region: United Kingdom
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
EMEA warranty - 1 year - pick-up and return
Bundled Services
1 Year Reliability Guarantee
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz
Slots Qty
2
Storage
Main Storage
256 GB SSD M.2 SATA
Display
13.3"
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare
Audio & Video
Graphics Processor
Camera
Camera Features
Face recognition, IR camera, Windows Hello
Sound
Harman/kardon stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard, AccuPoint, SecurePad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Wi-Fi CERTIFIED
3-cell Lithium Ion
Run Time
Up to 14.5 hours
AC Adapter
Input
AC 100/240 V
Output
20 V, 2.25 A
Connections & Expansion
Interfaces Details
2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3) , HDMI , Headphone/microphone combo jack , USB 3.0 (Sleep & Charge)
Memory Card Reader
Yes (microSD)
Software
Software Included
Toshiba Eco Utility, Microsoft 365 (30 days trial)
Case Material
Magnesium alloy
Security
Intel Authenticate
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
Localization
1.05 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
