Toshiba Portege X30 Core i7-8550U 16GB 1TB SSD 13.3" Detachable Touchscreen & Active Pen Core
Quicklinx: DXPFWS00 Mfr#: PT17CE-01U00GEN
Display Size: 13.3in
Processor Model: I7-8550U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 1TB
  • Core i7
  • IEEE 802.11n
£1,471.90 ex VAT
£1,766.28 inc VAT
  • The best way to get the job done
    If you need to get things done, you need the next professional 2-in-1 detachable. The Portege X30T-E. Supremely versatile, it can help you achieve whatever you need, no matter where you may be…in the middle of a power cut, delayed at the airport or simply in a meeting room with minimal connections. The bundled Keyboard Dock with full sized port layout and an astonishing battery life of up to 15.5 hours means you're ready for any business challenge. And the optional Travel Keyboard makes the device thinner and lighter for comfortable, efficient working on the go. You can also use it as a high performance tablet with a 13.3" touchscreen and kickstand, then boost your creativity with best in class hand writing or drawing via the optional Toshiba Universal Stylus Pen with Wacom AES Pen Technology optimised for Windows Ink. The Portege X30T-E. The best way to get the job done.
  • Performance and security you can depend on
    The X30T-E comes with all the performance and security you need for real peace of mind. 8th generation Intel Core processors, LPDDR3 RAM and ultra-fast SSD storage delivers the unthrottled performance you'd expect. While biometric multifactor authentication stops unwanted access in its tracks, keeping your data the way it should be – safe. And you can add an additional layer of security with the optional Smartcard Reader. Physical security and sheer robustness are proven too – the X30T-E meets military standards MIL STD 810G and has been tested to pass TUV HALT standards which simulate three years' usage. And it's all guarded by the Toshiba In-House BIOS for maximum security.
  • Nothing omitted. Nothing overlooked
    Every detail of the X30T-E has been created around you. Around helping you work faster and better, on the go or in the office. A 13.3? non-glare, high brightness Full HD screen means it's perfect for variable lighting. The Corning Glass means extra strength and more impact resistance, yet it also supports Touch and Pen input via the optional Toshiba Universal Stylus Pen with Wacom AES Pen Technology for unmatched writing experience. There's a 5mp camera on the back to enhance video capabilities alongside the traditional front facing camera. The kickstand angles the screen to a comfortable, stable position, it can even be securely lowered to comfortable angles for handwriting and drawing. Even the keyboard that comes as Keyboard Dock or optional Travel Keyboard version offers larger than usual keys with superb vertical pitch. The Portégé X30T-E. No opportunity has been missed.
  • Nothing can stop it. Or you
    Nothing stops the X30T-E performing, with connectivity that keeps you going no matter where you are. The optional LTE for instance, means internet on the go. This 2-in-1 detachable is bundled with a Keyboard Dock that comes with 2 x USB 3.0, 1 x Gigabit LAN, 1 x RGB, 1 x HDMI, 1 x USB Type-C for charging. Up to 15.5 hours of battery life easily covers the working day and makes it ideal for travelling. Need power in a hurry? A 30 minute charge brings four hours of battery. Fast performance is assured thanks to a special cooling developed by Toshiba, which keeps the CPU working at its peak. And whilst it's heavy on performance, it's light on weight with the tablet and Travel Keyboard coming in at just 1189 grams.
  • As if the 2-in-1 versatility wasn't enough, enhance your mobile performance with some great accessories
    Accessories like the Toshiba Universal Stylus Pen with Wacom AES Pen Technology optimised for Windows Ink, which allows you to express your creativity by quickly adding sketches or notes on the go. The Travel Keyboard and USB-C travel adapter keep you working on the go. The Portégé X30T-E with Keyboard Dock can be attached securely with the slim cable lock for additional peace of mind. For added protection, the stylish Toshiba X-Series sleeve protector in Onyx Blue will keep your Portégé X30T-E in pristine condition.
  • Services for a flawless performance
    The impeccable operation of your Toshiba/Dynabook product is our highest concern. To get the most out of your IT investment, we offer a wide range of Services that keep your day-to-day business running and perfectly fit your individual needs. Whether you would like to extend your standard warranty, upgrade your support level or manage your assets within one platform – we are the ideal partner at your side!
Dynabook Toshiba Portégé X30T-E-13H - 13.3" - Core i7 8550U - 16 GB RAM - 1 TB SSD
Tablet - with keyboard dock
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache /
16 GB LPDDR3
Storage
1 TB SSD
Display
13.3" touchscreen 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 620
Input Device
Keyboard, stylus, ClickPad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
2-cell - up to 14.25 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Matte black (keyboard), onyx blue with hairline
Dimensions (WxDxH) - tablet
31.6 cm x 20.7 cm x 0.91 cm
799 g
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
EMEA warranty - 1 year - carry-in
Bundled Services
1 Year Reliability Guarantee
Operating System
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
Cache
L3 - 8 MB
64-bit Computing
Intel Turbo Boost Technology
RAM
16 GB
LPDDR3 SDRAM
Speed
2133 MHz
Storage
Main Storage
1 TB SSD - (M.2) PCIe
Display
13.3"
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Corning Gorilla glass, anti-reflective
Audio & Video
Graphics Processor
Camera
Yes - Full HD (front), Full HD (rear)
Resolution
5 Megapixel (rear)
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, two microphones
DTS Studio Sound
Input
Keyboard Backlight
Glass clickpad, Wacom Active ES technology (AES) 2.0
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Wi-Fi CERTIFIED
2-cell lithium polymer
Run Time
Up to 14.25 hours
Battery Details
- 1 - lithium polymer - built-in battery , - 1 - lithium polymer - in keyboard dock
Connections & Expansion
USB-C (Power Delivery/data/video) , Headphone/microphone combo jack , HDMI (on keyboard dock) , 2 x USB 3.0 (on keyboard dock) , VGA (on keyboard dock) , USB-C (on keyboard dock) (charging) , Gigabit Ethernet (on keyboard dock)
Software
Software Included
Microsoft Office 365 (30 days trial)
Security
Intel Authenticate
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, USB-C power adapter, AES Stylus Pen
Localization
799 g
Dimensions (WxDxH) / Weight Details
31.6 cm x 21.7 cm x 2.21 cm / 1399 kg - tablet with keyboard , 31.6 cm x 20.7 cm x 0.91 cm / 799 g - tablet
ENERGY STAR Certified
Software applications
Toshiba Portege X30 Core i7-8550U 16GB 1TB SSD 13.3 Bundle deal on Toshiba Portege X30 Core i7-8550U 16GB 1TB SSD 13.3" Detachable Touchscreen & Active Pen Core
£1,571.07
Optical Storage: None
Graphics: Intel HD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Toshiba
Price Range Ex VAT: 1000 - 1500
