Whether you're in the office or on the move, the Portégé A30-C's durable, light magnesium chassis encompasses everything you need to stay productive. Small enough to carry with ease, but packed full of features that help you get more done, the Portégé A30-C helps you work more effectively - wherever you are. And with wireless connectivity, you can stay in touch with colleagues, and access all the data you need. The Portégé A30-C is designed to last, no matter where your working life takes you. Even after an accident, the Portégé A30-C will stay in working order - allowing you greater peace of mind.
Stay agile, stay productive
Whether you're in the office or on the move, the Portégé A30-C's durable, light magnesium chassis encompasses everything you need to stay productive. Small enough to carry with ease, but packed full of features that help you get more done, the Portégé A30-C helps you work more effectively - wherever you are. And with wireless connectivity, you can stay in touch with colleagues, and access all the data you need. -
Built for mobile working
The Portégé A30-C is designed to last, no matter where your working life takes you. Even after an accident, the Portégé A30-C will stay in working order - allowing you greater peace of mind. -
Secure on the move
One of the biggest issues with agile working is security with sensitive, business-critical data potentially at risk in public places. That's why the Portégé A30-C is equipped with dedicated TPM encryption. Designed to make data easily accessible but completely secure, the Portégé A30-C's two-factor authentication makes working on the move very safe. -
Eco-friendly
Take control of your environmental impact with the built-in Eco Utility. Quickly and easily customize your computer settings to maximize power efficiency, minimize energy consumption, and reduce the impact your work has on the planet.
- Dynabook Toshiba Portégé A30-C-13E - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 7 Pro (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 128 GB SSD
- Optical Drive
- DVD SuperMulti
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell - up to 13 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Black magnesium with precious hairline
- 31.6 cm x 22.9 cm x 2.24 cm
- 1.5 kg
- Localisation
- Region: United Kingdom, Ireland
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 1 year - carry-in
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD SATA
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HighBrightness, anti-reflective
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, stereo microphone
- DTS Studio Sound
Input
- Keyboard, touchpad
- Multi-gesture touch pad, Palm Rejection Technology
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 8260
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V
- Output
- 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- LAN , HDMI , Headphone/microphone combo jack , 3 x USB 3.0 , VGA , Dock
- Memory Card Reader
- Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card)
Software
- Software Included
- Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Studio Sound, McAfee LiveSafe (30 days subscription), Windows 10 Pro (DVD)
- Dockable
- Security
- Administrator password, USB Sleep-and-charge ports, 3D accelerometer
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.5 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
