Toshiba P300 3TB 3.5" SATA 6Gb/s 7200rpm 64MB High Performance Drive
Quicklinx: BPR7WS00 Mfr#: HDWD130UZSVA
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 3TB
Spin Speed (rpm): 7200rpm
More than 50 in stock
£57.01 ex VAT
£68.41 inc VAT
Toshiba’s P300 3.5" internal hard drive delivers a high performance for professionals. With its dual-stage actuator, you can count on smooth, responsive computing. What's more, your data and media is secured with a ramp loading design that prevents damage on the move, as well as a shock sensor. The P300 is available in capacities up to 3 TB.
  • High performance designed for everyday computing
    7,200 RPM speed with 64MB data buffer helps boost storage performance.
  • Data Protection technology
    Ramp loading technology reduces wear to the recording head and media for improved drive reliability. Built-in shock sensors detect impact, shielding adjacent track data.
  • Drive reliability
    Advanced Format (AF) technology helps improve formatting efficiency and the reliability of recorded data with stronger error correction algorithms.
  • Native Command Queuing (NCQ) support
    Optimizes the order in which received read and write commands are executed, resulting in increased performance and reduced mechanical workload from the drive.
  • Broad compatibility
    Industry-standard form-factor support compatibility with most PC.
Toshiba P300 Desktop PC - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal - Native Command Queuing (NCQ), Advanced Format technology, Data Protection Technology
3 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
101.85 mm x 147 mm x 26.1 mm
680 g
3 TB
3.5"
SATA 6Gb/s
Buffer Size
64 MB
101.85 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
RoHS
Package Type
Bulk
65 °C
Form Factor: 3.5"
Type: Hard drive
Capacity: 3TB
Brand: Toshiba
Price Range Ex VAT: 50 - 100
