Toshiba MG03SCA100 3.5" 1TB SAS 6Gb/s 7200RPM 64M HDD
Quicklinx: 9RG1WS00 Mfr#: MG03SCA100
The Toshiba MG03SCA series HDDs are designed to support enterprise applications where reliability, high capacity, and performance are required. The series is ideally suited for data archives and digital records storage, entry and business critical server and storage systems, disk backup systems—including remote sites for data protection and business continuity, and tiered virtual infrastructure for public and private cloud deployments (IaaS and PaaS).
With a top storage capacity of 4TB, the Toshiba MG03SCA HDDs utilize a traditional 3.5-inch form factor, enabling system builders to leverage 3.5-inch based storage chassis. The high-capacity, cost-effective models feature 7,200 RPM spin speed and leading-edge 6Gb/sec Serial Attached SCSI (SAS) and Serial ATA (SATA) interfaces.
Toshiba MG03SCA100 - hard drive - 1 TB - SAS 6Gb/s
Hard drive - internal - Error Correction Code (ECC)
1 TB
3.5" x 1/3H
SAS 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
101.6 mm x 147 mm x 26.1 mm
720 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
1 TB
3.5" x 1/3H
SAS 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
155 MBps
Seek Time
8.5 ms (average)
Average Latency
4.17 ms
Spindle Speed
7200 rpm
Reliability
MTBF
1,200,000 hours
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
11.3 Watt (active) , 6 Watt (idle)
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
70 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Vibration Tolerance
0.75 g @ 5-300 Hz (operating) / 5 g @ 5-500 Hz (non-operating)
Sound Emission
31 dB
