Toshiba Main Battery Pack 10.8v 9200mAh
Quicklinx: 8F2JWS00 Mfr#: CBI3265A
Device Screen Size: [N/A]
£60.35 ex VAT
£72.42 inc VAT
Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need
2-Power Main Battery Pack - laptop battery - Li-Ion - 9200 mAh
Laptop battery
0.58 kg
Lithium Ion 12-cell - 9200 mAh
Battery Form Factor
Internal
Batteries Qty
1
23.4 cm x 5 cm x 4.1 cm
1-year warranty
Dynabook Toshiba Satellite Pro L650/00, L650/02, L650/042, L670/01, L670/02, L670/029, T110/00, T110/009, T130/00; Toshiba Satellite A660, A660/07, A665, L630, L630/00, L630/037, L630/063, L645, L650, L670, L675, L750/03, L750/052, L755, L775, P750/02, P750/05, P755, T110, T130, T130/01, T130/03
Laptop battery
Battery Enclosure Type
Internal
Quantity
1
12-cell Lithium Ion
Voltage Provided
10.8 V
9200 mAh
Limited warranty - 1 year
23.4 cm
5 cm
4.1 cm
0.58 kg
Dynabook Toshiba Satellite Pro L650/00V, L650/00Y, L650/02W, L650/02X, L650/042, L670/01T, L670/01U, L670/029, L670/02E, L670/02U, T110/009, T110/00L, T130/00M, T130/00N , Toshiba Satellite A660/07S, A660-01S, A660-07P, A660-07R, A660-07T, A660-07U, A660-0TK, A660-15J, A660-BT2G25, A660-BT2N01, A660-BT2N22, A660-BT2N25, A660-ST2GX1, A660-ST2NX2, A660-ST3NX1, A660-ST5N01, A665-3DV1, A665-3DV5, A665-3DV6, A665-3DV7, A665-3DV8, A665D-S5175, A665D-S6082, A665D-S6083, A665-S5171, A665-S5177X, A665-S5179, A665-S5182X, A665-S5184X, A665-S5185, A665-S5187X, A665-S5199X, A665-S60100X, A665-S6055, A665-S6067, A665-S6085, A665-S6087, A665-S6094, A665-S6095, A665-S6097, A665-SP6002L, L630/00E, L630/037, L630/063, L630-01S, L630-02S, L630-03W, L630-05R, L630-06S, L630-07W, L630-08R, L630-09S, L630-BT2G01, L630-BT2N01, L630-ST203, L645-SP4006M, L650-02B, L650-ST2N03, L650-ST3N02X, L655-177, L655D-S5055, L655D-S5093, L655D-S5094, L655D-S5104, L655D-S5109, L655D-S5110, L655D-S5116, L655D-S5145, L655D-S5148, L655D-S5151, L655D-S5190, L655D-S5202, L655-S5059, L655-S5060, L655-S5166X, L655-S51WHX, L670D-ST2N03, L670-ST2NX1, L670-ST2NX2, L675D-S7046, L675D-S7050, L675D-S7052, L675D-S7053, L675D-S740GY, L675-S7051, L745D-SP4282RM, L750/03C, L750/03D, L750/04K, L750/04P, L750/052, L750/06P, L750/09J, L750/0L7, L750/0L8, L750/0L9, L750/0LM, L750/0LN, L750/0QM, L750D/009, L750D/00K, L750D/00U, L750D/011, L750D/017, L750D/030, L750D/031, L750D/034, L750D-BT5N11, L750D-ST5NX1, L750-ST4N01, L750-ST4NX2, L755-06M, L755-06P, L755-S5151, L755-S5255, L755-S5358, L770D-BT5N11, L770D-ST5NX1, L775D-S7223, L775D-S7340, L775D-S7345, L775-S7241, L775-S7243, L775-S7245, L775-S7248, L775-S7250, L775-S7252, P750/008, P750/01Y, P750/02J, P750/02K, P750/02L, P750/02Q, P750/02R, P750/02S, P750/02T, P750/03T, P750/05Q, P750/05S, P750/0MR, P750/0NW, P755-S5184, P770/09M, P775D-S5266, T110-00D, T110D-00C, T130/01E, T130/03X, T130-02F, T130-02M, T130-03F
Toshiba Main Battery Pack 10.8v 9200mAh Bundle deal on Toshiba Main Battery Pack 10.8v 9200mAh
£159.52
Brand: Toshiba
Price Range Ex VAT: 50 - 100
