Your basket is empty
Toshiba Laptop Battery Pack - Li-Ion - 5700 mAh
Quicklinx: B6M3WS00 Mfr#: PA3905U-1BRS
This Toshiba primary battery pack is a 6 cell, rechargeable, removable lithium ion battery. Avoid finding yourself on the road with a dead battery by adding extended power capabilities to your portable computer with an additional battery pack.
Toshiba Battery Pack - laptop battery - Li-Ion - 5700 mAh
Laptop battery
Lithium Ion 6-cell - 5700 mAh
Batteries Qty
1
26.9 cm x 4.8 cm x 2.6 cm
1 year warranty
Satellite R850; Satellite Pro R850, R950, S850; Tecra R850, R950
Laptop battery
Quantity
1
6-cell Lithium Ion
Voltage Provided
11.1 V
5700 mAh
Limited warranty - 1 year
26.9 cm
4.8 cm
2.6 cm
