Product
Brand
Toshiba Lamp module for TDP-T80/T90/T91/TW90/S80U/SW80U
Quicklinx: 9VQNWS00 Mfr#: TLPLW3
You never know when your lamp might fail, so it's smart to carry a back-up on business trips or keep a spare at your presentation facility. This replacement lamp from Toshiba is a lifesaver if your bulb burns out. This durable lamp will give you hundreds of hours of excellent, crisp, clear brightness.
Toshiba TLP-LW3 - projector lamp
Projector lamp
TDP-T80, T80E, T90, T90E, T90U, T91, T91E, T91U, T98, T98U, TW90, TW90E, TW90U
Projector lamp
Toshiba TDP-T80, T80E, T90, T90E, T90U, T91, T91E, T91U, T98, T98U, TW90, TW90E, TW90U
