Toshiba L200 500GB 2.5" 5400rpm 8MB Internal HDD
Quicklinx: BPR0WS00 Mfr#: HDWJ105UZSVA
Toshiba’s L200 2.5" internal hard drive is designed for everyday laptop users and gamers – and it's ideal for boosting and upgrading the storage capacity of your laptop PC or games console by up to 1 TB. Perpendicular Magnetic Recording and Tunnel Magneto-Resistive technologies also ensure fast, stable recording that makes the most of your hard drive space. Available in capacities of up to 1 TB, the L200 puts the renowned durability and reliability of Toshiba technology to work in your notebook or game console.
  • Upgrade your space
    For a large upgrade in a small device, the L200 HDD is capable of adding a lot of storage to laptops or game consoles, for quick and easy access to large gaming files, or everyday documents and media.
  • Advanced read and write technology
    Between the Perpendicular Magnetic Recording technology - which can deliver more than three times the storage density of traditional recording, and accounts for the L200's high capacity - and the Tunnel Magneto-Resistive recording technology - for improved stability - the L200 is equipped for fast and secure reading and writing of your data.
  • Keep data secure
    The L200's design includes an internal shock sensor, ensuring none of your data is lost. In addition, ramp loading technology means that when the hard drive or desktop PC are being transported, the drive slider does not make contact with the disk, making your data more secure.
Toshiba L200 Laptop PC - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal - shock sensor, Native Command Queuing (NCQ), Advanced Format technology
500 GB
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock sensor, Native Command Queuing (NCQ), Advanced Format technology
69.85 mm x 100 mm x 9.5 mm
107 g
3-year warranty
500 GB
2.5"
SATA 3Gb/s
Buffer Size
8 MB
69.85 mm
100 mm
9.5 mm
107 g
Performance
Drive Transfer Rate
300 MBps (external)
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 3 Gb/s
Compatible Bay
2.5"
RoHS
Package Type
Bulk
Limited warranty - 3 years
65 °C
