The TOSHIBA TEC B-SX5 thermal transfer / direct thermal printers extend the tradition of technical innovation of the TOSHIBA TEC high-class industrial printers. Built to succeed the very popular B-572 machines, they provide superior performance and reliability in a variety of industries including manufacturing, chemicals, pharmaceuticals, textiles, electronics and telecoms.
- Toshiba TEC B-SX5T - label printer - B/W - direct thermal / thermal transfer
- Printer Type
- Label printer - direct thermal / thermal transfer - B/W
- 20 kg
- Min Media Size (Custom)
- 30 mm
- Max Media Size (Custom)
- 140 mm
- Print Speed
- Up to 203 mm/sec - B/W
- Max Resolution (B&W)
- 306 dpi
- Interface
- Parallel, serial
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, NW-7, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, MSI-Plessey, Data Matrix, ITF, Kix (Netherlands) Post, RM4SCC, GS1 DataBar Omnidirectional
- Media Type
- Labels, thermal paper
- Fonts
- Courier, Helvetica, Letter Gothic, Prestige Elite, Times Roman, Gothic, Outline, Price, Presentation, OCR
- Printer Features
- RFID ready
- 29.1 cm x 46 cm x 30.8 cm
- Printer Type
- Label printer - direct thermal / thermal transfer - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- Parallel, serial
- 306 dpi
- Fonts
- Fonts Included
- 21 x bitmapped , 7 x outline
- Barcodes
- Printer Features
- RFID ready
Media Handling
- Media Type
- 30 mm
- 140 mm
- Max Printing Width
- 128 mm
- Max Printing Length
- 1498 mm
- Roll Maximum Outer Diameter
- 200 mm
- Roll Core Diameter
- 76.2 mm
- Expansion Slots
- 1 x expansion slot
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x parallel - 25 pin D-Sub (DB-25)
- Included Accessories
- Self-strip, ribbon saver
- RoHS, FCC Part 15 A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 144 Watt
- Power Consumption Stand by / Sleep
- 21 Watt
- Software Included
- Drivers & Utilities
Environmental Standards
- ENERGY STAR
- 5 °C
- 40 °C
- 25 - 85%
- 29.1 cm
- 46 cm
- 30.8 cm
- 20 kg
