Toshiba HSPR 120W - VGA/DVI-D/HDMI/Display Port/USB 2.0/USB 3.0/LAN
Quicklinx: FGY9WS00 Mfr#: PX5116K-3PRP
With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Toshiba Hi Speed Port Replicator III - port replicator - VGA, DVI, HDMI, DP
Port replicator
Video Interfaces
VGA, DVI, HDMI, DP
38.09 cm x 14.9 cm x 3.15 cm
720 g
United Kingdom
Power adapter 120 Watt
1-year warranty
Dynabook Toshiba Portégé A30, A30T, R30, Z30, Z30T; Toshiba Tecra A40, A50, Z40, Z40T, Z50
Port replicator
38.09 cm
14.9 cm
3.15 cm
720 g
Enclosure Colour
United Kingdom
4 x SuperSpeed USB 3.0 , 2 x USB 2.0 , 1 x display / video - DVI-Digital , 1 x display / video - HDMI , 1 x display / video - VGA , 1 x network - Ethernet 1000 - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - DisplayPort - 20 pin DisplayPort
Balance block
Security Slot Type
Kensington security slot
Power adapter
Power Provided
120 Watt
Limited warranty - 1 year
Dynabook Toshiba Portégé A30-C-1T3, A30-C-1VF, A30-C-1VJ, A30-D-12N, A30-D-14V, A30-D-154, A30-D-15Q, A30-D-189, A30-D-18T, A30-D-18U, A30-D-19R, A30-D-1C6, A30-D-1C9, A30-D-1CC, A30-D-1CH, A30-D-1CW, A30-D-1DF, Z30-B-12D, Z30-C-19L, Z30-C-1G5, Z30-C-1KK, Z30-C-1MD, Z30-E-11N, Z30-E-12F, Z30-E-12M, Z30-E-138, Z30-E-14G, Z30-E-14R, Z30-E-14T, Z30-E-15L, Z30-E-15Q, Z30-E-15X, Z30-E-15Z, Z30-E-16G, Z30-E-174 , Dynabook Toshiba Tecra A40-C-22F, A40-C-22X, A40-D, A40-D-10W, A40-D-12Z, A40-D-19U, A40-D-1C5, A40-D-1CJ, A40-D-1EF, A40-D-1EL, A40-D-1F2, A40-D-1G4, A40-D-1GC, A40-D-1HJ, A40-D-1HK, A40-D-1HL, A40-D-1HR, A40-D-1J0, A40-D-1J3, A40-D-1JD, A40-D-1K1, A40-D-1L9, A50-C-2ZK, A50-C-36R, A50-C-36Z, A50-C-37D, A50-C-37G, A50-C-37J, A50-C-37W, A50-C-37X, A50-C-382, A50-C-388, A50-C-38C, A50-D-1DW, A50-D-1E2, A50-D-1KW, A50-D-1L7, A50-D-1LJ, A50-D-1M4, A50-D-1N0, A50-D-1PG, A50-D-1PM, A50-D-1PP, A50-D-1PR, A50-D-1PT, A50-E-110, A50-E-11G, A50-E-134, A50-E-13J, A50-E-13K, A50-E-13L, A50-E1528, A50-E-19H, A50-E-19T, A50-E-1CT, A50-E-1E0, A50-E-1E2, A50-E-1J4, A50-E-1J7, A50-E-1J8, A50-E-1J9, A50-E-1K6, A50-E-1KR, A50-E-1LJ, A50-E-1MU, A50-E-1NN, A50-E-1PW, A50-E-1RZ, A50-E-1UR, A50-E-1UT, A50-E-1UZ, A50-E-1V3, A50-E-1V4, A50-E-1V5, A50-E-1V6, A50-E-1V7, A50-E-1V8, A50-E-1V9, A50-E-1VC, A50-E-1VD, A50-E-1WH, A50-E-1WJ, A50-E-1WK, A50-E-1WL, A50-E-1XF, A50-E-1XG, A50-E-1XJ, A50-E-1Z8, A50-E-1ZH, A50-E-200, A50-E-202, A50-E-20J, A50-E-20N, A50-E-20X, A50-E-217, A50-E-248, Z40-A-0GF, Z40-B, Z40-C, Z40-C-15K, Z50-C-139, Z50-C-18K, Z50-C-193, Z50-C-197, Z50-C-199, Z50-D-114, Z50-D-11U, Z50-E-10D, Z50-E-10T, Z50-E-10W, Z50-E-10X, Z50-E-10Z, Z50-E-114, Z50-E-11F, Z50-E-11K, Z50-E-11V, Z50-E-12J, Z50-E-12U, Z50-E-12Z, Z50-E-137, Z50-E-13V, Z50-E-14E, Z50-E-14F, Z50-E-14N, Z50-E-14W, Z50-E1522, Z50-E-15J, Z50-E-15K, Z50-E-163, Z50-E-166, Z50-E-167, Z50-E-169, Z50-E-16C, Z50-E-16D, Z50-E-16E, Z50-E-16F, Z50-E-16J, Z50-E-16R, Z50-E-16U
