Toshiba Hi-speed Port Replicator III 180W - UK Version
Quicklinx: 95XWWS00 Mfr#: PA5117E-1PRC
With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Toshiba Hi Speed Port Replicator III - port replicator - VGA, DVI, HDMI, DP
Port replicator
Video Interfaces
VGA, DVI, HDMI, DP
38.09 cm x 14.9 cm x 3.15 cm
720 g
United Kingdom
Power adapter - external 180 Watt
Dynabook Toshiba Portégé R30, Z30; Toshiba Tecra A50, W50, Z40, Z50
Port replicator
38.09 cm
14.9 cm
3.15 cm
720 g
Enclosure Colour
United Kingdom
4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - DisplayPort - 20 pin DisplayPort
Security Slot Type
Kensington security slot
Power Provided
180 Watt
Dynabook Toshiba Portégé R30-A-10H, R30-A-114, R30-A-11J, R30-A-11K, R30-A-129, R30-A-134, R30-A-139, R30-A-13C, R30-A-147, R30-A-14K, Z30-A-108, Z30-A-10J, Z30-A-10P, Z30-A-10W, Z30-A-10X, Z30-A-10Z, Z30-A-115, Z30-A-116, Z30-A-11G, Z30-A-120, Z30-A-12N, Z30-A-12P, Z30-A-12Q, Z30-A-12T, Z30-A-12U, Z30-A-12X, Z30-A1301, Z30-A1302, Z30-A-136, Z30-A-138, Z30-A-13P, Z30-A-13W, Z30-A-13X, Z30-A-15W , Dynabook Toshiba Tecra A50-A-10H, A50-A-10J, A50-A-10X, A50-A-12C, A50-A-12E, A50-A-12M, A50-A-12N, A50-A-12P, A50-A-12Z, A50-A-130, A50-A-139, A50-A-13C, A50-A-13M, A50-A-13N, A50-A-13W, A50-A-13Z, A50-A-140, A50-A-150, A50-A-151, A50-A-15R, A50-A-168, A50-A-16E, A50-A-16Z, A50-A-171, A50-A-17P, W50-A-102, W50-A-103, W50-A-104, W50-A-107, W50-A-10G, W50-A1500, Z40-A-10T, Z40-A-111, Z40-A-112, Z40-A-115, Z40-A-11L, Z40-A-11U, Z40-A-11Z, Z40-A1401, Z40-A1402, Z40-ABT1400, Z50-A-106, Z50-A-10D, Z50-A-10N, Z50-A-11H, Z50-A-11J, Z50-A-11K, Z50-A-11Q, Z50-A-11R, Z50-A-11V, Z50-A-120, Z50-A-12T, Z50-A-12W, Z50-A-12X, Z50-A-13E, Z50-A-13M, Z50-A1501, Z50-A1502, Z50-ASMBN22
95XW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
95XW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.51
95XW C2G 10m Select High Speed HDMI with Ethernet In Stock £41.66
95XW C2G 15m Select High Speed HDMI with Ethernet In Stock £55.88
95XW C2G Pro HDMI to VGA Converter In Stock £51.51
