Balance of Speed & Storage Capacity
Ideal for PCs and Console Gaming
500GB
8GB MLC NAND
5400rpm
64MB Buffer
SSD-Like Performance and HDD-Like Capacity
Toshiba's SSHD recorded the score of PCMARK® Vantage several times higher than the conventional HDD.
Optimized self-learning caching algorithm
Toshiba's SSHD dynamically learns the access pattern in each system and directs data to the appropriate tiers, that are DRAM, NAND and disk media. High speed access is achieved by storing frequently-accessed data to NAND.
NAND flash memory controller technologies
Toshiba also develops leading-edge microscopic memory technology in NAND. This experience enables Toshiba to boost the NAND technologies, such as defective blocks management, ECC (Error Correction Code), conversion of logical block address, and wear-leveling.
Cost Performance
Toshiba's SSHD is a lower cost alternative to SSDs while keeping close to SSD performance by the optimized NAND configuration.
High Anti-Oscillation Performance with RV Sensors
As a feature engineered to raise performance and reliability, an RV sensor detects increased vibration to help curb the impact of such shaking.
Game on
The next generation of video games demand powerful storage to keep up - enter the Toshiba H200 SSHD, the perfect companion to any gaming laptop. It gives you access to all your best games at a moment's notice, for less interruptions, and more action. The perfect device for upgrading your PC, the H200 delivers a higher capacity, faster boot-up, and enhanced responsiveness - even when you're running multiple applications. -
The best of both
Combining the storage capabilities of a hard drive with the performance and responsiveness of a solid state drive, Toshiba's H200 hybrid SSHD drive is ideal for laptop users who require large, high-performance storage - giving you the best of both worlds. -
The quick learner
By storing your most frequently-accessed data to NAND, the H200's optimized self-learning caching algorithm means you get faster access to the files you use the most, and need the quickest. This self-learning algorithm, optimized by Toshiba for 2-bit-per-cell MLC NAND, continues to develop throughout the lifespan of the drive, constantly improving your PC's performance. -
Keeping data secure
The H200's dual-stage actuator and RV sensor improve positional accuracy, negating the effects on head-track alignment that vibrations can cause. This design makes for more precise, faster read and write speeds for instant access to your data. -
Advanced read and write technology
Between the Perpendicular Magnetic Recording technology - which can deliver more than three times the storage density of traditional recording, and accounts for the H200's high capacity - and the Tunnel Magneto-Resistive recording technology - for improved stability - the H200 is equipped for fast and secure reading and writing of your data.
- Toshiba H200 - hybrid hard drive - 500 GB - SATA 6Gb/s
- Hybrid hard drive - internal
- Capacity
- 500 GB
- Flash Memory Capacity
- 8 GB
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- Spindle Speed
- 5400 rpm
- RV Sensor, shock sensor, Native Command Queuing (NCQ), Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA)
- 69.85 mm x 100 mm x 7 mm
- 92 g
- Capacity
- 500 GB
- 8 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Buffer Size
- 64 MB
- 69.85 mm
- 100 mm
- 7 mm
- 92 g
Performance
- Average Latency
- 5.56 ms
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- RoHS
