Product
Toshiba H200 1TB 2.5" 5400rpm 64MB 8GB NAND Hybrid SSHD
Quicklinx: BPR9WS00 Mfr#: HDWM110UZSVA
1 on order, delivery delayed
Toshiba’s H200 2.5" internal solid state hybrid drive (SSHD) combines the storage capabilities of a hard drive with the performance and responsiveness of a solid state drive giving you large, high-performance storage that's ideal for gamers and everyday users. The H200’s fast read speeds are achieved through an optimized self-learning caching algorithm, providing quick access to your frequently-used applications, game saves, and data.
  • Game on
    The next generation of video games demand powerful storage to keep up - enter the Toshiba H200 SSHD, the perfect companion to any gaming laptop. It gives you access to all your best games at a moment's notice, for less interruptions, and more action. The perfect device for upgrading your PC, the H200 delivers a higher capacity, faster boot-up, and enhanced responsiveness - even when you're running multiple applications.
  • The best of both
    Combining the storage capabilities of a hard drive with the performance and responsiveness of a solid state drive, Toshiba's H200 hybrid SSHD drive is ideal for laptop users who require large, high-performance storage - giving you the best of both worlds.
  • The quick learner
    By storing your most frequently-accessed data to NAND, the H200's optimized self-learning caching algorithm means you get faster access to the files you use the most, and need the quickest. This self-learning algorithm, optimized by Toshiba for 2-bit-per-cell MLC NAND, continues to develop throughout the lifespan of the drive, constantly improving your PC's performance.
  • Keeping data secure
    The H200's dual-stage actuator and RV sensor improve positional accuracy, negating the effects on head-track alignment that vibrations can cause. This design makes for more precise, faster read and write speeds for instant access to your data.
  • Advanced read and write technology
    Between the Perpendicular Magnetic Recording technology - which can deliver more than three times the storage density of traditional recording, and accounts for the H200's high capacity - and the Tunnel Magneto-Resistive recording technology - for improved stability - the H200 is equipped for fast and secure reading and writing of your data.
Toshiba H200 - hybrid hard drive - 1 TB - SATA 6Gb/s
Hybrid hard drive - internal
1 TB
Flash Memory Capacity
8 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
64 MB
Spindle Speed
5400 rpm
RV Sensor, shock sensor, Native Command Queuing (NCQ), Halogen Free, Tunnel Magneto-resistive Recording (TMR) Head Technology, Ramp Load, Perpendicular Magnetic Recording (PMR), Advanced Format technology, Dual Stage Actuator (DSA), Data Protection Technology
69.85 mm x 100 mm x 9.5 mm
117 g
1 TB
8 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
64 MB
69.85 mm
100 mm
9.5 mm
117 g
Performance
Average Latency
5.56 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" x 1/8H
Power Consumption
3.3 Watt (read) , 3 Watt (write) , 0.75 Watt (low power idle)
RoHS
Package Type
Bulk
60 °C
Shock Tolerance (operating)
350 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
900 g @ 1 ms half-sine pulse
Vibration Tolerance (operating)
1 g @ 5-500 Hz
Vibration Tolerance (non-operating)
5 g @ 15-500 Hz
Sound Emission
25 dB
